On the distributor cap going clockwise it starts at 1, then 8 4 3 6 5 7 2
Make sure your rotor tip points to #1 cyl is at tdc (#1 is the front most cyl on the drivers side). With the cap on start your wires there (firing order)
You might notice that the GM LSx order departs from the SBCs and adopted the same firing order as used in the Ford MOD motors. However, because Ford and GM number the cylinders differently, the firing order appears to be different.
Anywayz.... Just some trivia that might come in handy some day.
