Had our car in shop for intermitant starting issue
That was thought to be related to wiring connections ended being related to bad fuel filter. Now we get to next problem. After I picked up the car I found the normally freezer like auto temp ac now does not turn the blower on at all no matter where I set the stat when I use manual mode I can make fan work with some cold air and surges of hot air with stat in coldest setting. Any experts in this subject want offer suggestions thanks byron.
Look on youtube for the self test video your climate control will tell you.
I did the self rest scenario. Problem is the mentioned flashing light does not flash at all indicating all is well. When continuing with test no code is displayed just 00. clearly there is problem not letting the fan run at all in auto mode
Take a look at the module on the ac housing on the pass side under the hood.
