OP - might be more advantageous to actually address the cooling issue you seem to feel you have.
Do you actually have an issue? If you feel you do what are you using as determining that "maybe" PCM tweaks will help? Are you using the analog gauge in the dash as an information device? It's not thought to be accurate or often even close.
For a '95 you should be able to use the GAUGES function on the DIC to display the temps the ECM is actually seeing from the CTS in the cluster LCD. Have you replaced the CTS recently?
I'm guessing the car has no issues but he just wants the car fans to come on earlier. Can you tell him on how to do that?
I had my fans reprogrammed to come on early by my tuner up in Vancouver Washington. There is a guy up in Roseville, Roman I believe his name is that does custom tuning. If you have the ability to flash your computer you could do it yourself if you know (or someone here can tell you) which table to change.
Changing the fans makes a BIG difference, you will be happy with the results.
Thats what im looking for is a reflash i do not know how. And i do not have the program for that . And no there are no issues i just dont like the temp myvette runs at in traffic with ac off
