Starting Problem
Had no problems for a long time,need help now.Not turning over like it should,slow once this week did not turn over at all,not even a click,
watied a good while and it started but turned slow.had the battery checked today and the guy at the auto said take it home and charge it all night and bring it back in the morning and he would check it again.Any ideas would help.
thanks jim
OP - How old is the battery? If you don't know learn how to check "date codes" or just buy
Take your battery to a local electrical shop/battery retailer and leave it with them to charge appropriately to check. You should have the charging system checked by maybe the same facility using professional equipment UNLESS you've appropriate devices and actually understand them. Judging from your post you don't.
If the charging system is deficient the "new battery" suggested by "AF2" is foolish.
