Courtesy light dimmer board
Old Jun 29, 2016 | 04:23 PM
monte k's Avatar
monte k
Default Courtesy light dimmer board
Hi
I have a 84 and the courtesy light do not
Come on except when turning the light switch.
Through research I feel it's the courtesy light dimmer board.
I've been under the dash onthepassenger side and can't find it anywhere.
I understand it's usually taped to another wire bundle?
Thanks for the help
Monte K
Anderson, INTO
Old Jun 29, 2016 | 06:06 PM
gerardvg's Avatar
gerardvg
Originally Posted by monte k
Hi
Thanks for the help
Monte K
Anderson, INTO
Hi
It is under there, see link below what it looks like you can get just the boards for $35. No need to buy the board with the plastic cover for $130, extra 100 bucks for the plastic and yes the delay timer is there somewhere you may need to remove the knee pad or plastic I think. Note the numbers on the plastic cover, there are 2x different boards the info is there on the links.
My car is R/H drive so nothing is where it is meant to be but it is under the passenger dash, I have gone through a couple of delay timers over the 20 years I have had my 85.
http://www.parts123.com/corvettecent...50f&ukey=24420
http://www.parts123.com/corvettecent...50f&ukey=29596
http://www.parts123.com/corvettecent...50f&ukey=29998
Old Jun 29, 2016 | 06:09 PM
monte k's Avatar
monte k
Ok and thanks for the info��
And yes I bought the board, why pay 100. For a plastic box
Monte K
To Courtesy light dimmer board
