Dyno Sheet
Old Sep 10, 2002 | 12:26 AM
FSTRNU's Avatar
FSTRNU
Default Dyno Sheet
I just had my car dyno'ed tonight for a base line so i can compare after I do the heads and cam. I had 249.3 hp with 259.5 torque.
According to the Dyno they had I had a Max HP @362.2 and Torque @ 317.5. If I had a scanner I would post them but it will have to be tomorrow. It was a little lower than I wanted I was looking for around 265-275 at the wheels but it didnt happen oh well. He let me run it out I hit 161 @5500 rpms not bad for 3.73 gears. :cheers:
Old Sep 10, 2002 | 01:55 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Dyno Sheet (FSTRNU)
:cool: What is your goal for the end result? :cheers:
Old Sep 10, 2002 | 01:06 PM
FSTRNU's Avatar
FSTRNU
Default Re: Dyno Sheet (Rob 91Z07)
I would like to see 350-400 but we will have to see.
Old Sep 10, 2002 | 01:09 PM
scorp508's Avatar
scorp508
249rwhp translate into about 296hp on a 6-speed and 303hp on an automatic.
To Dyno Sheet
