small rubber plug found???
Old Jul 3, 2016 | 05:38 PM
mat1227's Avatar
mat1227
Default small rubber plug found???
While replacing my Opti this weekend (94) I found this small rubber plug sitting on the passenger side tire, I didn't remove it and have no idea where it came from, assume it stuck to my arm from some where that my arm was wedged into so many tight spaces, and came off when I was leaning on the tire. I did change the plugs and wires also. Any one have any idea? It's maybe 3/4" dia if it was all round.
Mark
Old Jul 3, 2016 | 05:46 PM
WVZR-1's Avatar
WVZR-1
I'd say it's likely the plug that closes the end of the weatherstrip that's on the top of the inner wheel houses. Check both ends of the weatherstrip on that side!
Old Jul 3, 2016 | 06:16 PM
mat1227's Avatar
mat1227
You are 100 % Correct, the ones on the drivers side were close to coming out also. Thank you.
Mark
Old Jul 3, 2016 | 07:51 PM
ZeeAreOne94's Avatar
ZeeAreOne94
2016 C4 of Year Finalist
noth
After seeing this thread I had to check mine....and they're missing. Are those plugs purely cosmetic or do they serve a purpose? Doubtful that you can still get them from GM.
Cheers!
Old Jul 3, 2016 | 10:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Cheers!
I would think cosmetic and to prevent stuff from getting into the w/s
Old Jul 4, 2016 | 12:49 PM
ZeeAreOne94
noth
Guess I'll try to locate some.......thanks!
To small rubber plug found???
