Info Cluster
Old Jul 10, 2016 | 06:20 PM
j86pc's Avatar
j86pc
Default Info Cluster
There is a grey wire that comes from Eng. and Metric switch but I can't find the wire it goes to under the dash. All I see is a pink wire with black stripe that has the same connection. Any thoughts?
Old Jul 10, 2016 | 07:02 PM
j86pc's Avatar
j86pc
Manual (c60)
Old Jul 10, 2016 | 07:04 PM
j86pc's Avatar
j86pc
Back lighting of the cluster? But that wire comes off of metric / English switch in the center of the console.
Old Jul 10, 2016 | 08:33 PM
Hooked on Vettes's Avatar
Hooked on Vettes
There should be two gray wires at one side of the Eng/Met switch.
One of the Gray wires goes to pin A2 of the Dash Cluster. The other Gray wire which appears to be the one in your hand would go to a mating connector that changes the wire color to Dark Blue and goes to the HVAC C68 Control Head Pin D16.
Since you have C60 manual AC you have no digital display and that wire is not used.
When the switch is in Metric position it sends the proper voltage to the Dash Cluster and C68 control head to display the data in Metric.
Old Jul 10, 2016 | 09:20 PM
j86pc's Avatar
j86pc
Thanks HoV.
To Info Cluster
