94 power antenna
Old 07-22-2016, 04:41 PM
94corvetteC4
94corvetteC4's Avatar
Default 94 power antenna
My antenna is stuck in the up position. The motor works, it's the ribbon that is the issue. I need to kill the power to the antenna till I can get a new mast. What is the best way to kill the power to the antenna?
Any recommendations on a fixed low profile or a hidden antenna options?
Old 07-22-2016, 06:05 PM
WVZR-1
WVZR-1's Avatar
Received 2,271 Likes on 2,032 Posts
IP Fuse #37 I believe (LH CTSY) should disable the antenna.
Old 07-22-2016, 06:46 PM
94corvetteC4
You sir are correct. I pulled the fuse and turned the ignition on and off several times and the antenna is dead. Now I have time to research my antenna options to see which rout I want to go.
I would just go for a new mast but the price range is all over the map. Anywhere from $9 to $85. I'm kinda iffy on the low dollar antenna because I seem to think its going to be either a very thin metal that will bend easily or pour chrome finish that will flake maybe even a cheap nylon ribbon that will brake or strip in a short period of time.
I wouldn't mind a short rubber antenna or one of those amplified antennas that go behind the window pillar.
Old 07-23-2016, 12:57 PM
94corvetteC4
Well that didn't work as planned. Pulling that fuse also killed my speakers. The creeks squeaks and road noise is unbearable. Guess I will have to figure out how to get to the motor and unplug the power from there.
Old 07-24-2016, 07:28 AM
WVZR-1
WVZR-1's Avatar
I thought you might be more interested in "shutting it down" QUICKLY rather than the alternatives.
I've never done a '94 but I believe there will be 2 connectors plugged into the rear of the BOSE/Antenna relay in the storage compartment. You can unplug the antenna from that relay I'd think and retain the Bose function.
RH storage compartment either taped to the body harness or maybe attached but easily spotted.
I kinda thought someone might have confirmed this later in the evening after I mentioned the "FUSE" removal.
Old 07-26-2016, 02:45 AM
jimduffy
jimduffy's Avatar
yes have same issue on my 87 so found relay to disconnect , still can use radio but antenna still up yea had mask fixed 10 yrs ago and just broke same way , figuring my options, good luck
Old 07-26-2016, 09:57 AM
thunder1951
thunder1951's Avatar
When I bought my Vette last October it had the antenna stuck in the up position, I could push it down and it would come back up when I turned on the radio and stay up, I found a new OEM delco on ebay for 100 bucks and that solve the antenna issue for me.
Old 07-26-2016, 12:15 PM
antfarmer2
antfarmer2's Avatar
Just pull the relay under the back trim by the latch.
Old 07-26-2016, 12:35 PM
WVZR-1
WVZR-1's Avatar
You have I think a '94 and you've had your "HANDS ON" this relay?
Old 07-29-2016, 09:51 PM
94corvetteC4
Further research has lead me to a two wire connector, orange and pink wire under the glove box tray. I know the pink wire supplies the power to the antenna but not sure what the orange wire feeds. I'll disconnect that connector tomorrow then put the fuse back in. I suspect the orange wire will be for my rear interior lights.
Old 07-29-2016, 10:28 PM
WVZR-1
WVZR-1's Avatar
Following up from my post #5
What are you trying to accomplish now?
I do believe that at the Bose relay in the RH storage compartment there will be a connector that will detach leaving the Bose working and disabling the antenna. Try ORANGE - WHITE
What are you calling "GLOVE BOX TRAY" - RH Storage compartment?
This isn't from a '94 FSM but should be very similar to your car:
Name:  RH Storage.png
Pay NO ATTENTION TO THE COMMENT TO "Antfarmer2" - there's no relay where he mentions in the '94.
To 94 power antenna
Quick Reply: 94 power antenna
