Any tips for replacing right side head light pucks ?
I changed both sides on my '93 Ruby, seemed pretty equal in degree of difficulty - and probably one of the easier c4 repairs i've attempted. There are good U-tube videos that really help.
I guess being right or left handed could affect things.
Do both sides tho, the 2nd one is always much easier!
Bueno Suerte
Bueno Suerte
Headlight pucks
Driver side vs Passenger side difference: gear cover is reversed and I found the passenger side a bit more tricky than the left. Passenger side gear was stuck inside housing and it took some doing to remove it. I also "notched" the gear on the passenger side so I could install it back into the housing without a struggle. Vaseline or white grease is handy in keeping those little washers in place during assembly and for a light coating on the gears. I used compressed air to blow out the dust and particles that were left over from the old pucks. I bought a kit on ebay that included both gears and 6 pucks for $38 shipped. Total time around 3 hours including cleaning up after the job.
JWASR64 (07-29-2016)
I did this repair on my 88 back in 2001. First time I had ever attempted a repair like this other than doing regular engine or suspension work. At that time I had no YouTube or camera phone for help but did have the Corvette Forum. That's when and why I joined. This repair will take you a good afternoon.
http://www.bing.com/videos/search?q=...322C&FORM=VIRE
Pretty good video which walks you through the process.
