hot start problem
Old Aug 17, 2016 | 07:09 AM
oldtimer's Avatar
oldtimer
Default hot start problem
ok experts give me a clue.. my 92LT1 has a problem at times not always when warmed up when starting it will hit a few times then die. I've replaced the throttle position sensor, ignition module ,plugs and wires, cleaned the throttle body, runs like a champ but this nagging problem exits Any thought would be appreciated next step dealer if I cannot locate problem thanks
Old Aug 17, 2016 | 07:34 AM
WVZR-1's Avatar
WVZR-1
Hit a few times?
Runs a few moments and stalls or exactly what is the issue? Always when hot and has sat for a very short time OR occasionally? Cold first start of the day is how long? Do you key-on and wait OR do you just insert key and crank?
Old Aug 17, 2016 | 10:34 AM
JimLentz's Avatar
JimLentz
Do you get any codes?
Old Aug 17, 2016 | 12:01 PM
oldtimer's Avatar
oldtimer
Originally Posted by WVZR-1
Hit a few times?
first start of the day no problem. After driving, then stopping shutting off engine, restarts are the problem the engines runs a few seconds then dies, it will always starts but several attempts are needed at times. I key and crank . Thanks for your interest
Old Aug 17, 2016 | 01:10 PM
antfarmer2's Avatar
antfarmer2
How old is your fuel filter? Any codes? See what is missing fuel or spark.
Old Aug 17, 2016 | 07:11 PM
WVZR-1's Avatar
WVZR-1
Try "key-on WAIT then crank" a few times. It would be a very good idea to hang a fuel pressure gauge and drive it for several trips that would normally create issues and observe. Costs very little to "observe" I'd throw no parts at it until I had "observed/checked".
To hot start problem
