Security
Old Aug 21, 2016 | 12:21 PM
SpidersInMyBed's Avatar
SpidersInMyBed
Cruising
Default Security
I have a 84, and was sold the car without a keyfob. The security keeps going off and the only way I can shut it off is to disconnect the battery. Is there a way to bypass or permanently disconnect the system so I don't have to worry about it. Thanks
Old Aug 21, 2016 | 12:39 PM
antfarmer2's Avatar
antfarmer2
Try turning the key all the way locking then unlocking.
Old Aug 21, 2016 | 12:40 PM
markKlein's Avatar
markKlein
There was no fob from the factory. Your owners manual should explain how the alarm system works. If it keeps going off for no reason, check the door switches. If one of them is malfunctioning the alarm can be activated apparently at random.
Old Aug 21, 2016 | 12:41 PM
SpidersInMyBed
Cruising
I'll have to give the key in the door lock and see if that works. It's the factory alarm (horn honking, wont turn over). It usually happens when the door is unlocked, and I return to the car and just open the door.
Old Aug 21, 2016 | 12:42 PM
SpidersInMyBed
Cruising
BTW, thanks for the quick reply
Old Aug 21, 2016 | 01:00 PM
antfarmer2's Avatar
antfarmer2
Might need to clean the contacts.
Old Aug 21, 2016 | 03:13 PM
SpidersInMyBed
Cruising
Originally Posted by bow tie guy
I'd talk to you on the phone my number is in your private message inbox
beats the typing of 20 questions
oh guess not you can't receive private mesaages
Hmmm, guess not, appreciate the offer thou
To Security
