6 speed transmission question
Purchased my first corvette (used 91 corvette) two weeks ago. About time--I'm 67 years old. Ran the VIN at the dealers and it came up with codes ML9--transmission,manual 6 speed and MN6--transmission, manual 6 speed provisions(merchandising option).....the dealer says the MN6 means nothing. Is the dealer correct? Thanks
Update...the Service Parts Identification sticker located between the bucket seats under the console (?) cover also lists both codes ML9 and MN6. The aluminum plate attached to the tranmission says ZF type S6-40...parts list number 105200036 if that helps.
Thanks!
Thanks!
Update...the Service Parts Identification sticker located between the bucket seats under the console (?) cover also lists both codes ML9 and MN6. The aluminum plate attached to the tranmission says ZF type 56-40...parts list number 105200036 if that helps.
Thanks!
Thanks!
What exactly is your question Brother?
Google is your friend... from Google below
ML9 - RPO - RPO Codes - GM-Trucks.com
www.gm-trucks.com › GM-Trucks.com › Pages › RPO Codes
ML9. ... Latest RPO Code Comments. ravageur1972's Photo · LV3 · ravageur1972 - Dec 17 2014 08:49 PM. THawkey71's Photo · ZQ8 · THawkey71 - Dec 23 ...
cnct34 (08-29-2016)
MN6 is "marketing/sales" information.
An A4 would display
MD8 - GMSPO 4L60 for parts/service reference
MX0 - "sales/marketing" information
cnct34 (08-29-2016)
Congratulations on the new Corvette and Welcome to the forum.
If you want to learn more about the ZF 6 speed try looking at
http://www.zfdoc.com/
He is quite respected as the expert about our 6 speeds and has a lot of information on his site.
