trans indicator lite
Old Aug 29, 2016 | 10:58 PM
A Peter C4's Avatar
A Peter C4
Default trans indicator lite
94 auto c4 shift(gear) indicator lite does not illuminate,how would I change bulb?or check power to bulb socket need access instuctions looked at FSM coulde not find directions.
Old Aug 29, 2016 | 11:20 PM
antfarmer2's Avatar
antfarmer2
Screws in the console and ashtray.
Old Aug 30, 2016 | 12:35 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Note that the shift **** on an A4 has a different removal process. Remove the button to find a snap ring instead of a threaded rod. After removal of the snap ring the **** just pulls straight up and off.
Also note that you will find 2 lamp sockets under the shift plate. One of them will be empty and has no wires going to it. Why? No one seems to know but some here have run power to that empty socket and now have extra brightness for the shifter indicator.
Old Aug 30, 2016 | 03:18 AM
Cliff Harris's Avatar
Cliff Harris
My theory is that they used the same shifter mechanism on several different cars and some use the socket in the front.
Old Aug 30, 2016 | 08:59 PM
HAD2HAV2's Avatar
HAD2HAV2
Buy a LED bright white bulb to replace the old filament type that came with your car. You'll be glad you did. Now's a good time to replace the shifter boot and **** if they are both well worn. When putting the console back on make sure the orange/red shift indicator lines up with the shifter pin (what ever it is called).
Old Nov 4, 2016 | 11:27 PM
A Peter C4's Avatar
A Peter C4
Any video or detailed instructions would be nice as I don't want to break indicator orange pin when replacing bulb,boot and **** are in good condition.
To trans indicator lite
