Speedo Gears
Old Aug 30, 2016 | 08:39 PM
902066's Avatar
902066
Default Speedo Gears
Anybody give me a couple of options for where to buy Speedometer Correction gears?
Switching from a 3:73 gear to a 4:10 ratio. Thanks
Old Aug 30, 2016 | 08:54 PM
WVZR-1's Avatar
WVZR-1
You can't do a "mechanical correction" with out changing drive and driven. The only person I know that sells both reasonably is Marc
http://www.zr1specialist.com/HAT%20W...on%20Gears.htm
It's nearly to the point where a person is maybe better off with an ERA/DRA and there's maybe 3 (a stretch) that are considered quite reliable.
**** OP never mentioned ZF but "902066" seemed a reasonable "userID" for C4 ZR-1 so I mentioned the ZF solution.
Old Aug 30, 2016 | 09:22 PM
Patsgarage's Avatar
Patsgarage
I good had luck with Bowtie overdrives when I needed to setup the 700r4 for my 68 Caprice, I'm just not sure if your year C4 has a different setup.
Old Aug 30, 2016 | 10:24 PM
STEVEN13's Avatar
STEVEN13
This is the where I purchased mine. He only had the 13 count gear (for the tail shaft). It's very close as verified on my GPS. 4.11 (9" Ford rear).
In my case, I found it easier to remove the tail shaft housing to install (trans was out already).
To Speedo Gears
