1989 starting problem
Old Sep 10, 2016 | 06:51 AM
scotman1955's Avatar
scotman1955
Default 1989 starting problem
ok i have been chasing this problem for a while have replaced ICM -FUEL RELAY-IAC-COIL-OXY SENSOR-TEMP SENSOR-PLUGS-PLUG WIRES-FUEL FILTER-FUEL SENDING UNIT-i dont know what to next im looking at changing all the fusable links or the injectors ? have been reading about this problem but have not read about a fix.need some help please: also car will start fine run fine as soon as i shut off it will not start for hours
Old Sep 10, 2016 | 08:03 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
won't turn over or won't fire
Old Sep 10, 2016 | 09:43 AM
scotman1955
no it turns over fine will not fire up for a few hours
Old Sep 10, 2016 | 09:44 AM
scotman1955
Old Sep 10, 2016 | 11:48 AM
Cruisinfanatic
does it have spark and fuel?
Did you check fuel pressure?
You're throwing money away guessing
Old Sep 11, 2016 | 06:49 AM
scotman1955
it does it starts and runs and stay running it when i shut it off it will not restart
Old Sep 11, 2016 | 08:02 AM
Cruisinfanatic
so I'll ask again
When it won't start:
Old Sep 11, 2016 | 08:32 AM
scotman1955
so i guess i need to ask if it starts it has spark and fuel when it does not start i will check that this am
Old Sep 11, 2016 | 05:06 PM
scotman1955
it has spark and 44lbs of fuel pressre
Old Sep 18, 2016 | 05:31 PM
mcguirjf's Avatar
mcguirjf
I'm just gonna leave this here.
FIC Connection - $180 for stock rebuilt Bosch 3's injectors
FYI - Multec (original) injectors are garbage!
Old Sep 19, 2016 | 08:07 PM
old90vet's Avatar
old90vet
1st Gear
  • If u have hei distributor check ur ignition module. I just had to change my.
To 1989 starting problem
