CD player
Old Sep 10, 2016 | 10:34 AM
BLUDICE's Avatar
BLUDICE
Default CD player
The CD player does not work - the battery was replaced when I bought the car last month - security feature makes the CD player inoperative - requires security code - nothing in the owners manual explaining how to correct - help please.
Old Sep 10, 2016 | 11:36 AM
WVZR-1's Avatar
WVZR-1
I don't recall '94 (I believe you've mentioned this before) having DELCO-LOC. If yours is a factory Bose is it maybe just displaying ERR? ERR is not LOC.
What brand radio/receiver if not OE/Bose? What year car is it? You posted in C4 but is it maybe something "other than" C4?
Old Sep 10, 2016 | 12:32 PM
BLUDICE's Avatar
BLUDICE
'94 w/Bose - it's mention in the Corvsport site that a code has to be entered after there's a lack of power to the unit.
Old Sep 10, 2016 | 12:35 PM
PatternDayTrader's Avatar
PatternDayTrader
Post the link cause I don't think that's right either. The theftloc radios didn't show up until 97 or 98 if memory serves.
Old Sep 10, 2016 | 12:43 PM
Richard Raichert's Avatar
Richard Raichert
Default My 94 Bose/gold unit
No code on mine.
Old Sep 10, 2016 | 12:51 PM
BLUDICE's Avatar
BLUDICE
Corvsport.com
1994
Vin/options
Old Sep 10, 2016 | 01:20 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If it really needs a code, I am thinking you don't have a factory audio unit.
When I had the factory stereo in my '96, I had the battery disconnected many times and it never needed a code.
In fact, I've never seen any mention of a code in any owners or service manual.
Old Sep 10, 2016 | 01:29 PM
RollaMo-LT4
Corvsport.com
1994
Vin/options
I just looked at what it says about the '96 also.
I don't think they are posting correct information on the security feature.
To discourage theft, the CD player required an electronic security code input after battery disconnect.
This part is correct though
A power delay feature was added to all models which permitted the stereo system and power windows to operate after the ignition was switched to "off" or "lock". Power was cut after the driver's door was opened or after 15 minutes, whichever came first.
Old Sep 10, 2016 | 01:36 PM
RUU's Avatar
RUU
Same with mine.
Old Sep 10, 2016 | 01:57 PM
BLUDICE's Avatar
BLUDICE
It's a factory unit - does nothing when I insert a CD - like there's no power to it - AM-FM works fine - if a security code is required where would I find it and how do I enter it?
Old Sep 10, 2016 | 02:19 PM
RollaMo-LT4
There is NO security code for a factory 1994 Corvette stereo.
Can you post up a picture of the unit?
Old Sep 10, 2016 | 02:51 PM
Yukon Corleone's Avatar
Yukon Corleone
C4 of Year Finalist (stock) 2019
The 1990 with the Delco GM Bose does require a 6 digit code if you somehow you get locked out. My question for you is this, does the CD player even work? To me it does not from what you describe and it is the CD player itself since the radio does work. Let us know what you find out.
How to unlock the CD/Radio/Cassette is in the owners manual. If you can't find it I will look it up when I get home.
The original owner might have set the code. I set the code on mine and I am the original owner.
Old Sep 10, 2016 | 03:33 PM
BLUDICE's Avatar
BLUDICE
I have the original Owners Manual and no mention of unlocking CD.
Old Sep 10, 2016 | 03:37 PM
Yukon Corleone
I will look it up when I get home from work but with with any luck someone else will find it out sooner.
Old Sep 10, 2016 | 04:21 PM
WVZR-1's Avatar
WVZR-1
If the unit had DECO-LOC you would have nothing and the display would show LOC/LOCKED or something very specific. I've not done a Delco-Loc for many years and I don't recall the scenario.The retrieval then wasn't difficult. You have clock and station display?
Down 3/4 way in this link is what I recall about DELCO-LOC - looks very familiar with the retrievals that I've done many years ago BUT never with a C4.
http://www.radio-code.com/GM-RDS_explained_code.htm
A dealer could likely accommodate you if you provided the information from the display inquiry in the link.
Old Feb 26, 2017 | 10:57 PM
4xcontractor's Avatar
4xcontractor
Cruising
Bluedice, Did you ever get you CD player unlocked?
Old Feb 27, 2017 | 04:36 PM
BLUDICE's Avatar
BLUDICE
Nope - gave up trying - PO put a 6 CD changer in it so I'm good - just wondered if there was something else to the factory one - thanks.
To CD player
