1984 Engine Questions
Old Sep 13, 2016 | 06:07 PM
Jlab013's Avatar
Jlab013
Cruising
Default 1984 Engine Questions
Hi guys. I am looking for some advice, I went to check out a 1984 Corvette today and I had two specific questions. I drove the car for a few minutes and the transmission was smooth but once it was parked and we lifted the hood I noticed a knocking that got slightly louder as it stayed idle. One of the guys said that it's normal because that's the noise of the cross fire fuel injection. I am wondering if that is true or just some bs that was said.
The other question is that when I took the oil cap off there was no resistance, usually when you take an oil cap off when the car is running you have some suction which would hold the cap in place. On this car it came right off. Just looking for some in site into these concerns.
Thanks,
Josh
Old Sep 13, 2016 | 07:53 PM
ex-x-fire's Avatar
ex-x-fire
The injectors do tick quite loudly. I never noticed any pressure in the valve covers. Look down into the hole at the rockers. Is the engine clean?
Old Sep 13, 2016 | 08:59 PM
jseremba's Avatar
jseremba
You have determine where the noise is coming from. It could be a bad bearing. My 84 did not have any knocking noises.
Old Sep 13, 2016 | 09:59 PM
Hot Rod Roy's Avatar
Hot Rod Roy
For the bs/truth test, remove the air filter cover, then touch the tip of a long screwdriver to the injectors, and the end of the handle against your ear. Is that the noise the seller is calling "normal"?
I haven't noticed any "knocking" noise from my CrossFire injectors.
Old Sep 13, 2016 | 10:14 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The OP needs to better describe what he means by "knocking".
Knocking sure wouldn't be normal.
But as ex-x-fire mentioned, those throttle body injectors can "tick" quite loudly, and if your not used to hearing them might think something is wrong.
Old Sep 15, 2016 | 01:44 PM
2vettes2go's Avatar
2vettes2go
the 1984 does not have injectors, it has a throttle body and does not make noise. lifters do and so does rod knock.
Old Sep 15, 2016 | 03:02 PM
RollaMo-LT4
Throttle Body Injectors will most certainly make a "ticking" sound.
Some probably louder than others.
How do you think they supply fuel?
Old Sep 16, 2016 | 10:22 AM
corvettenorway's Avatar
corvettenorway
Old Sep 16, 2016 | 05:47 PM
Hot Rod Roy
In previous posts, you have said that you bought your '84 in 1983. As a very long term owner, this is a surprising comment! I'm sure you have heard of CFI? You must know what that stands for! Is your car in a museum someplace? Have you ever taken off your air filter cover? It's a real education under those two black *****! What are we missing here?
Old Sep 17, 2016 | 01:31 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Say what? Do you even know what a CFI motor looks like? It has two TBs and two injectors if it is stock. Also, the injectors do make a ticking sound as they fire...knocking no, but they do make a ticking noise. Yet another post for CFI mis-information.
Old Sep 17, 2016 | 11:32 AM
gjohnson's Avatar
gjohnson
I read that the transmissions in the 84's can have a knocking problem. This was fixed in later model 700r's.
Old Sep 17, 2016 | 11:42 AM
BrandensBeast's Avatar
BrandensBeast
The transmission in my 84 is VERY clunky, putting it in drive and reverse really shift the car almost making it jerk and rattles the whole car, driving it completely fine, mine has a carb on it so not sure about the crossfire...
Old Sep 18, 2016 | 04:52 AM
RustyCFI's Avatar
RustyCFI
I do think we need more word on if this is actual engine knock or just one of the ticks coming from several sources, mainly those injectors.
For the OP, can you check the exhaust? Do you smell rotten eggs faintly? Are the bolts to the cat rusted or slightly so, indicating it is original? A clogged old cat could be causing back pressure and causing a few issues. Try going up a hill and seeing if it struggles more than it should.
Old Sep 18, 2016 | 09:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
If its a knock that gets louder as the oil gets warmer no its not normal rods can do that though
Old Sep 18, 2016 | 11:50 AM
Sid.123's Avatar
Sid.123
Tps switch...I know these make it hard to start if the idle voltage is to high...
Old Aug 10, 2017 | 09:43 AM
Klgrayson's Avatar
Klgrayson
Has his car been modified or he just doesn't understand the 1984 set up
To 1984 Engine Questions
