Bose 101, can anyone tell me what the single white wire is and the plug with 2 wires. I'm guessing pink is for antenna. I plugged the radio into car and the antenna started to go up and stopped, now when I power the radio the antenna relay just clicks, is it bad?
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
dont worry about the white wire. Most vettes don't use it. Does the radio play? Check fuses. Radio and CTSY
Ok, are you talking about the single wire with the black plug, or the white plug with the 2 wires? The one I am asking about is the white plug with 2 wires.
Should be the 12V (Orange) but I cant remember if it's constant power or only when the ignition is on. I do know that if you opt out of a Bose main unit but keep the Bose amps with speakers, the kit that allows you to do so has this attachment that plugs into that plug. I'm not sure what the brown wire on that plug is for but it's either another ground or has something to do with the amps.
