No Start !!!
Old Oct 18, 2016 | 05:27 PM
jimfed's Avatar
jimfed
Default No Start !!!
I turn the key and nothing happens, wait a few minutes and it starts sometimes. I bypassed the VATS system years ago with a plug and play bypass it's never been an issue so I would rule that out. We tested the starter and it is fine. The one thing we did notice is that when you turn the key to the on position there was no power getting to the starter. Car would not start last weekend had it towed to a friends shop where it sat for a couple of days he tugged on the wiring harness behind the battery and it started, not sure if this was the answer but i have it home and started it a few time with no issues yet. Tomorrow I will see if if starts but I was wondering if anyone came across this problem before ?
Old Oct 18, 2016 | 05:40 PM
kg4fku's Avatar
kg4fku
Little more info would help us out.
What year is the car?
Auto or manual?
Do the dash lights and interior lights stay on when you turn the key to the start position or do they dim or go out completely?
Does the starter relay click when the key is turned to the start position?
Have you cleaned the battery posts and tightened the battery connectors?
Has there been any recent work done to the car?
Old Oct 18, 2016 | 05:48 PM
antfarmer2's Avatar
antfarmer2
Pull the battery and clean the jump block behind it.
Old Oct 18, 2016 | 05:55 PM
jimfed's Avatar
jimfed
The battery is new and the car is spotless with 13K miles on it, never been stored outside.
Old Oct 18, 2016 | 05:56 PM
jimfed's Avatar
jimfed
What year is the car? 1986
Auto or manual? automatic
Do the dash lights and interior lights stay on when you turn the key to the start position or do they dim or go out completely? No
No
yes
stereo system with amplifier
Old Oct 18, 2016 | 05:58 PM
jimfed's Avatar
jimfed
The battery is new and I will check the jump block !
Old Oct 18, 2016 | 06:06 PM
antfarmer2's Avatar
antfarmer2
What the hell does have to do with the jump box behind it? If yours has one that is where I would look. The year sure would help!
Old Oct 18, 2016 | 06:11 PM
Hooked on Vettes's Avatar
Hooked on Vettes
I turn the key and nothing happens, wait a few minutes and it starts sometimes. The one thing we did notice is that when you turn the key to the on position there was no power getting to the starter.
The starter motor requires 12 volts for the start motor which comes from a direct connection from the positive terminal of the Battery.
When you turn the key to Start (Not On/Run) 12 volts from the ignition switch passes thru the Starter Enable relay which is located behind the driver information center and is closed/energized if the key pellet matches what the VATs decoder module is programmed for.
The 12 volts then goes thru the Park Neutral safety switch for an automatic trans or the Clutch Safety switch for a manual trans then to the Starter Solenoid terminal which is a Purple wire.
The Ground for the Start motor is the engine block which is connected by a cable from the engine block to the negative battery terminal.
If you don't measure 12 volts on the Purple wire when the ignition switch is in the Start position you need to find out why there is no 12 volts.
Old Oct 18, 2016 | 06:17 PM
kg4fku's Avatar
kg4fku
with all above. Need to know more than what you provided. If you answer the questions I asked before I am sure we can help you narrow the issue down.
A car with 13K miles is not immune to electrical issues even if stored inside so that bit of info can be thrown out.
Old Oct 18, 2016 | 06:22 PM
jimfed's Avatar
jimfed
1986
The jump box is like new, I cleaned the area when I last changed the battery last year.
Old Oct 18, 2016 | 06:25 PM
jimfed's Avatar
jimfed
we checked the power going to the solenoid with the key in the on position and it wasn't getting any power to it.
Old Oct 18, 2016 | 06:41 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
1986
I think these guys are suggesting that you check/clean the terminals, themselves. It's nice to have everything tidy...even "armorall'ed but the metal to metal connection is what is important. So did you actually check the connections?
Hooked On Vettes gave you the path of continuity from Batt/ignition to starter. All you need to do is get out a meter and start testing. Easy.
To No Start !!!
