Factory engine installation
Old Nov 5, 2016 | 01:20 PM
dc6902's Avatar
dc6902
Default Factory engine installation
Does anyone know how c4 engines and transmissions were installed from the factory? Where they installed from the top or where they installed from the bottom with the front suspension?
Old Nov 5, 2016 | 02:34 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Enjoy!
Old Nov 5, 2016 | 03:07 PM
dc6902's Avatar
dc6902
Default I thank you!
Going to rebuild front suspension, replace engine, transmission at same time.
Old Nov 5, 2016 | 05:19 PM
Hawaii89vette's Avatar
Hawaii89vette
Default I pulled and reinstalled the Engine and Trans from the top
when I rebuilt my 89 engine, I pulled the engine and auto trans together from the top. The hood was removed. I put them back in from the top.
Old Nov 5, 2016 | 05:42 PM
antfarmer2's Avatar
antfarmer2
Bottom with suspension like every other factory I have been in.
Old Nov 5, 2016 | 07:13 PM
jay23ls's Avatar
jay23ls
Originally Posted by Hot Rod Roy
What a cool vid, thanks for sharing!
Old Nov 6, 2016 | 02:28 PM
Rod Schneider's Avatar
Rod Schneider
When I rebuilt my 87 engine a couple of years ago, I lifted the body up and left the entire power train, front crossmember, transmission, C beam, and rear suspension assembly on the floor. It was very easy to do and I'd do it that way again if I needed to pull the engine! (I do have a lift.....)
Old Nov 6, 2016 | 07:34 PM
cuengineer's Avatar
cuengineer
If I remember right, the 1996 white C4 in the video fell through the sinkhole but was repaired by GM including all of the signatures.
Old Nov 6, 2016 | 08:51 PM
Edv92c4's Avatar
Edv92c4
The car you are thinking of is the 1,000,000 th corvette. It is a 1992 white with a red interior. It just so happened that I took a plant tour in the summer of 1992 and at the end of the tour the guide showed us the car as it was still parked at the end of the line (had been built a couple weeks before) from the cerimony the plant had upon its completion. The museum hadn't been built yet. In 2014 I went to the museum and saw the sink hole as well as the same car before it was repaired by GM. It was sad to have seen it new as well as after its damage. I was glad to hear that GM repaired it.
Old Nov 6, 2016 | 08:57 PM
Edv92c4's Avatar
Edv92c4
Loved that video. I remember on the plant tour standing in that spot where they start the cars for the first time...and watching the workers turn the wheels all the way left...then right...to get the power steering fluid through the system. I remember thinking to myself "so this is the first thing they do to a corvette when it comes to life"
Old Nov 7, 2016 | 08:00 PM
jts90vette's Avatar
jts90vette
2021 C4 of the Year - Unmodified Finalist
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
https://www.corvetteforum.com/forums...g-to-life.html
Old Nov 7, 2016 | 09:01 PM
Edv92c4's Avatar
Edv92c4
Cool thread!
Old Nov 8, 2016 | 12:53 PM
86C4Z51's Avatar
86C4Z51
To Factory engine installation
