FSM help
Old Nov 5, 2016 | 06:50 PM
jseremba's Avatar
jseremba
Default FSM help
Hi
My coolant fan, 1989 Corvette 6 spd with auto air, is not going on. All of the sensors are new, 1 month or so old. Where in this Fn FSM is the fuse block diagram with the description of which fuse does what? And the coolant fan diagnosis 8A-31 talks about table1 and table 2 where are these tables.
Thank you
Old Nov 5, 2016 | 07:06 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by jseremba
Hi
Thank you
Table 1 and Table 2 are on 8A-31-4
8A-11-0 thru 8A-11-10 should cover all of the FUSED distribution
Old Nov 5, 2016 | 09:30 PM
jseremba's Avatar
jseremba
Thank you, Shortly after my rant I found everything except the diagram that tells which fuse does what. I know that some of the fuses do double duty but they are not listed on the fuse panel. I did have a diagram with all of the functions of each fuse. I thought I got it from the FSM but I cannot find it, this time. I will look again when I am a little less angry.
thank you
Old Nov 5, 2016 | 10:55 PM
A Peter C4's Avatar
A Peter C4
My owners manual shows all fuse locations and ids but its a 1994 base
Old Nov 6, 2016 | 06:49 AM
jseremba's Avatar
jseremba
I know that some where in this manual is a chart with the IDs. Drives me nuts. Thank you
Old Nov 6, 2016 | 08:15 AM
WVZR-1's Avatar
WVZR-1
I don't ever recall seeing such a chart - FUSE assignments vary much in older GM's depending upon options. 8A-11 covers each individual FUSE distribution as you asked for your car.
Old Nov 6, 2016 | 08:30 AM
Renfield's Avatar
Renfield
The FSM came so highly recommended. It's a lesson in frustration. Like somebody took all this useful information and put it in a blender.
I love it when it says "See XYZ" with no page, chapter, section, etc. By the time I find XYZ, I forgot why I was looking for it in the first place.
It's driving me to drink.
To FSM help
