need a screw
Old Nov 13, 2016 | 09:57 AM
nutsy's Avatar
nutsy
Default need a screw
parden the title,lol. i noticed a screw missing on the bottom of the body. it actually has a bolt head, its the one right where it says to put the jack behind the front tire. it holds the body up against the frame, black in color on my 94. any help appreciated. thanks, Nutsy
Old Nov 13, 2016 | 10:34 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Take one of the others out and go to a hardware or auto parts store and find a match.
Old Nov 13, 2016 | 03:44 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I thought I was going to have to check my internet security after this post title.
Old Nov 13, 2016 | 05:15 PM
nutsy's Avatar
nutsy
yah but i try to keep everything original as possible. especially since car only has 14k miles and only thing not original are the tires. im **** like that. i wonder if i can go to the dealer and get it.
FOURSPEEDVETTTE, I couldnt resist,lol.
Old Nov 13, 2016 | 05:41 PM
WVZR-1's Avatar
WVZR-1
There's "NO BOLT TO BODY" in the location you mention - Are you wanting maybe the left fender panel lower rear bolt? This is a bolt that you'd need to remove to service the battery. You would insert an end wrench between the rocker finish and the fender panel to access it.
If yes it's an M6 X 1.0 X 25 with a self-starting pilot with I believe a flange head. Very common to the entire damn car and on the shelf at nearly every car dealer foreign and domestic in your local area.
*** Or maybe a rocker molding screw?
Old Nov 13, 2016 | 07:41 PM
antfarmer2's Avatar
antfarmer2
If you you want a good screw go to OT. if you want a original 94 screw send me the replacement and a self addressed box and I will give you mine off my 94.
Old Nov 14, 2016 | 01:16 AM
Joe C's Avatar
Joe C
sounds to me like you're looking for a standard m4.2 - 1.41 x 20 self tapping, hex head, sem screw (12mm washer).
nothing unique about these screws to worry about originality - I mean, its not like it has a date code or anything - . these are a standard part and used all over the place on your corvette. sold at a variety of places - dealers, hardware stores, autozone, advanced, etc.. FWIW, I keep boxes of these, and other standard hardware around the shop - http://www.clipsandfasteners.com/M4_...w_p/a12742.htm
another standard part and the mating end of the screw is the nylon retaining grommet.
http://www.clipsandfasteners.com/Sea...=11&Search.y=9 these are used to retain the rocker panel, and interior door panels. like the screw, you can get these just about anyplace. over years, these things get brittle, crack, break, get over assembled, and sometimes just fall out. while you're at it, you may want to check the mating end of that missing screw.
Old Nov 14, 2016 | 05:01 PM
nutsy's Avatar
nutsy
thats it Joe, thanks for the links and info. ill see if i can find one locally first.
Old Nov 14, 2016 | 05:40 PM
Joe C's Avatar
Joe C
PM me with your shipping info - i'll send a couple OE parts - no charge.
Old Nov 15, 2016 | 04:51 PM
nutsy's Avatar
nutsy
really appreciate it Joe, thanks again
To need a screw
