which may to buy
which may to buy
I am curious any recomendations. Cardione or bwd. For a May on an 85...pigtails replaced same issue and 33 code so it replacement time
I am not sure what an May is.
From the code 33 it looks like you are talking about a MAP (manifold absolute pressure) sensor.
Sorry, but I can not recommend one brand over another since I never had to replace one or look into it.
Good luck.
Good luck.
Received 1,597 Likes
To the OP, I have used Cardone parts in the past with good results. If you do have a K&N installed, remove it and get the car running right before you do anything else.
C4 of Year Finalist (appearance mods) 2019
That is certainly possible. It had a similar issue with my 95 when I put on a K&N. After the oil problem I switched back to the paper filters and never had the issue again.
