Locking Gas cap
Old Nov 25, 2016 | 09:15 PM
funtoy's Avatar
funtoy
Default Locking Gas cap
Help, somehow I don't have my key for the locking gas cap.
Anyone have suggestions?
Old Nov 25, 2016 | 10:42 PM
Dt86's Avatar
Dt86
Pick it, they are pretty simple locks.
Old Nov 25, 2016 | 11:47 PM
A Peter C4's Avatar
A Peter C4
If all else fails see locksmith
Old Nov 26, 2016 | 05:52 AM
hcbph's Avatar
hcbph
I suspect they have very simple keys, who knows they may all be the same within any particular brand. Maybe see if anyone around you has the same cap, maybe try their key on yours.
Old Nov 26, 2016 | 07:15 AM
Renfield's Avatar
Renfield
Not hard at all. Small flat blade screwdriver and a spring steel hair clip. Tickle the tumblers as you turn.
Or the ugly way. Screw in a slide hammer and give it a yank.
Old Nov 29, 2016 | 07:56 PM
funtoy's Avatar
funtoy
Thank for the info. I will post some pics when I have the time to remove the cap.
Have a great week!
Old Nov 30, 2016 | 06:42 AM
rfn026's Avatar
rfn026
While we're on the subject of C4 gas caps......
Make sure the gasket on the cap is really good. Then make sure the drain hole is not plugged.
It the drain hole gets plugged the well will fill with water and possibly leak into the gas tank. You can end up with a gas tank full of water.
This doesn't happen very often but it does happen.
Richard Newton
The C4 Callaway
To Locking Gas cap
