Speakers
Old Dec 3, 2016 | 09:50 PM
85VetteZR1's Avatar
85VetteZR1
7th Gear
Default Speakers
Anyone know what's the biggest speaker that will fit in the rear speaker compartment of an 85 Vette? I know there will be modifications to fit anything bigger than the 4" that's there now. Just seeing if anyone out there as fit a bigger speaker
Old Dec 3, 2016 | 10:10 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
In the rear? I have 6x9's in mine.
Old Dec 3, 2016 | 10:15 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
10" subs mounted on home made baffles. Not what I'd call the best woofer location though...as the CF is kinda small for good low-end.
Old Dec 3, 2016 | 10:38 PM
85VetteZR1's Avatar
85VetteZR1
7th Gear
6x9's.. awesome thank you. Did you install the 6x9's or did someone else?
Old Dec 3, 2016 | 10:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Someone else did; they were in the car when I got it.
Old Dec 3, 2016 | 11:08 PM
zapc's Avatar
zapc
if you dont have Bose, a 6x9 is the factory size speaker, any non bose speaker cover will be set up for the 6x9 or you can cut yours
Old Dec 3, 2016 | 11:18 PM
85VetteZR1's Avatar
85VetteZR1
7th Gear
Ok everyone thanks for the help. Mine does have the Bose system. I want to install some Alpine 6x9's.
Old Mar 11, 2020 | 01:17 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Radio
Bose has amplifiers at every speaker.
get a new radio.
you will burn out trying to get the bose to work with those speakers
Old Mar 12, 2020 | 12:11 AM
FAUEE's Avatar
FAUEE
I have 8" subs in mine. I custom cut an mdf baffle to mount them. They work great. I wouldn't run 6x9s there, as they will have like 6 tweeters on them most likely which will reflect off the rear glass and screw up your staging. If I had to use 6x9s, I would disconnect the tweeters from them.
Old Mar 12, 2020 | 11:55 AM
daverulz's Avatar
daverulz
Same here - had to flip one sub out of phase to eliminate cancellation but they sound great with about 250 watts each. From the research I did I think I remember reading somewhere around .5 cubic feet in the enclosures back there.
To Speakers
