I am going to refresh my suspension over the winter. My biggest point is to replace all of the bushings that I can with Polyurethane. There is a shop in town that allows you to rent lift time. I would like to rebuild my control arms with new bushings and balljoints up front and new tie rod ends all the way around. In order to do this in a timely fashion I would like to have a second set of control arms ready to bolt on to my car in order to reduce "downtime" or what needs to be done at the shop.
Is there a Control Arm rebuilding service? If not, does anyone have a spare set of control arms?
I have a set of cores for you to build or you could use as cores. These were removed from a '95 to replace with new. I sent you a PM with an email address.
Read through this, notice there are links for the next 2 sections at the top, which cover the actual bushing installation in the front and rear. I also provided the links here for you.
