aftermarket gauges
aftermarket gauges
Hi all,
Anyone that has installed extra gauges how did you mount them ? I'm thinking about getting a couple and looking for mounting ideas but I don't want to cut holes in the dash.
What year? Supposedly the Atari dash was done by others, The newer 90 and up, I haven't seen but would be interested if it isn't a huge PITA.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I went with post gauges!
U.S. Air Force
A 2&1/6" gauge will fit perfect in an air conditioner vent. I have a boost gauge mounted in the first center vent. You will need to remove the air deflector vanes.
Single gauge A post modules at Auto Zone heat with heat gun to shape tight to pillar put in pins and add sheet metal screws to secure if you want.Did this to my Toyota to add oil pressure gauge it worked very nice,sorry no pic. It was under $20. Ecklers $45.
If you're looking at you're gauges during an autocross you're not going fast enough.
Richard Newton
Richard Newton
I am having the entire digital dash in my 89 removed and a custom panel fabricated in its place. I am going with all Speedhut and the speedometer will be GPS driven. I will have a tach., Speedo, oil pressure and temp., volts, fuel, and water temp. in my custom panel, along with new turn and high beam indicator with headlights and dimmer, and driving light switches.
