custom superram?
Old Sep 19, 2002 | 12:47 AM
hngacurv's Avatar
hngacurv
Default custom superram?
I was looking at pictures of the superram on LPE website and the entire time I'm reading about it I'm thinking I can make the box. I wouldn't have anyway to make the base manifold, but has anyone else thought of trying a custom box on stock l98 runners(maybe even siamesed)? I have no idea what this would do for performance overall though.
Old Sep 20, 2002 | 03:00 AM
Kevin91Z's Avatar
Kevin91Z
Default Re: custom superram? (castivers)
I wish GM would have done something like the SuperRam for our TPI cars, instead of what we're stuck with. If the runners went into the bottom of the plenum like a SuperRam instead of the sides, we'd have a lot more performance. But oh well, cant change that now.
I dont see why you cant buy any aftermarket base, and fabricate your own runners and plenum, if you can do that sort of thing. I got myself some SLP runners, and a friend of mine is siamesing them 5/8 of the way in.
Pics: http://para.noid.org/~thresher/image...ze=800&start=0
Old Sep 20, 2002 | 03:14 AM
sinistervette's Avatar
sinistervette
As far as a base goes, go to a swap meet and buy a used tunnel ram intake. Remove the bolt on plenum, machine the base, make a plenum box with a TB on the front, machine the base for the fuel injectors and fuel rail(this is the toughest part), assemble unit! This is what I was working on, but holley beat me to the punch. It is quite a good high rpm high hp set up. Now I'm going with the stock TPI, and I'm using all the stock components, just going to modify the daylights out of it! I hope to make it suitable for 7000+ rpm and high rpm hp. I'm not much into torque, so that is why I'm trying to achieve the high rpms. Go ahead and give it a try, you won't really know for sure until you try it yourself! :D :cheers:
Old Sep 20, 2002 | 11:50 AM
hngacurv's Avatar
hngacurv
Default Re: custom superram? (sinistervette)
Appreciate the replies.
[Modified by castivers, 3:51 PM 9/20/2002]
Old Sep 20, 2002 | 11:53 AM
scorp508's Avatar
scorp508
Well, it can be done, but keep in mind it isn't "just a box". :) It has its shape for a reason.
Old Sep 20, 2002 | 01:29 PM
vettmech's Avatar
vettmech
Default Re: (scorp508)
Look at some pictures of the engine in the old Sledgehammer Corvette that LPE did the engine for. It was a Holley tunnel ram base with what apears to be an L-98 plenum with the sides welded up and new holes cut into the bottom............ :seeya
Old Sep 20, 2002 | 05:12 PM
hngacurv's Avatar
hngacurv
Default Re: (vettmech)
So far I have only been able to find one picture of it. Big article to go along with it. This is something i'm going to have to read later. http://www.callawaycars.com/Corvette...er_article.htm
Old Sep 22, 2002 | 08:03 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
I know the intake you are talking about and from what I recall I think it looks awfully like what we now call a Stealth Ram...
Old Sep 22, 2002 | 12:04 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: (Red 90 L98 Coupe)
yea wouldnt it be easier to just buy a stealth ram :yesnod:
To custom superram?
