DMITTZ Corvette build Vol.2
#421
It had no trouble hauling this 1,600lb lathe in the bed for several hours. Don't know what I would do without access to a truck!
#422
So today I did the final install of the sway bar components and lubricated the suspension. Everything went together without issue. The new sway bar and endlinks are super easy to work on.
Some pictures...
I also took it off the jack stands and since I now only need a 1/8 wheel spacer the front wheels/tires tuck into the wheel wells a bit nicer than before.
I still need to adjust the front ride height up about 1in before I start driving it, but it looked kinda cool for the picture.
-DMITTZ
Some pictures...
-DMITTZ
#423
bet that feels great!
any leaks from the OD pan after hylomar so far?
#424
The future trans oil changes should be nice now though since I can just reuse the hylomar rather than fooling around with RTV.
#426
Thanks Colabear.
#427
Custome Super Ram Intake Lid
Hi everyone,
So I have been waiting a while for this and I know a few of you have been excited to see my custom super ram lid.
Anyway, this evening I finally got to pick-up the custom made lid and I am very pleased.
Some pictures:
I still need to do the finishing work since I only hired out the actual machining work.
The plan for the lid from here is to polish the raised surfaces of the lid and powder coat all the other surfaces.
More updates to come.
-DMITTZ
Some pictures:
-DMITTZ
#428
very cool lid!!!
that is unique and very creative. what gave you the direction for the concept?
#431
I had also considered having the word 'Corvette' machined into the lid or a C4 logo but in the end I prefered this 'sleaker' design.
#432
Thanks Branden and 1LEZ. I'm very happy with how it turned out.
#433
Here's a couple of pictures I took early this morning of the lid sitting on the engine.
The lid is not sitting right just yet because it seems to have been machined slightly oversized on the passenger's side but, it is only a small amount of material the needs to be removed so that shouldn't be to hard to fix.
-DMITTZ
-DMITTZ
#434
I'm impressed by your work.
If you think that South Bend was difficult, take a look over at: http://www.owwm.org/
There's people there that have to break it down then use roll-backs to move some of their respective equipment. Some of it's unbelievable how big they can go moving things. Take a look for some threads on matchers and there's even one about a lathe for turning masts.
#435
Ya moving the lathe was not as bad as I thought since we just broke it down to unload, took about 2.5 hours and that included reorganizing the workshop to fit it in. There were No 'scary' moments during the process.
I actually have a pretty heavy duty tilt-deck trailer with a winch etc... that I considered using. However its sooo much nicer to just take the truck for longer distance and cross boarder stuff as far as fuel costs, driving in traffic and insurance go, not to mention the place I picked this up from we could hardly back the truck into the place, it was so crowded.
There was actually a SB16 and also 14.5 for sale a little closer to me for the same price but I figured this was the biggest lathe I could move without buying equipment or hiring help.
Some guys are very inventive and move some crazy huge machines just for hobby use, But for me I can't ever see needing a bigger lathe for my own hobby use. A SB 16/24 or an old monarch would be pretty fun to look at in my workshop though.
#436
I got the super ram lid 'fitted' to the plenum. I put a belt sander in my bench vise and then ground off just a little material from a couple spots on the lid and now it fits very well.
I also had to enlongate some of the bolt holes since a few of them were'nt placed quite right but the bolt heads should still cover the holes so it should be fine.
Super Ram lid all fitted:
-DMITTZ
-DMITTZ
#438
Super Ram Intake
Hi everyone,
So today I got started on the polishing process for the intake lid.
I hand sanded the raised surfaces starting at 120 grit and worked up to 600 grit. I plan to sand it upto 2000 grit before I start polishing.
BV85 (06-02-2017)
#439
Supre ram intake
Hi everyone,
I have a bit of an update for you all.
So I spent some time and wet sanded the lid all the way upto 2000grit sand paper...
Next I started with a course compound and worked my way to a finer polishing compound. Here is the result:
I put a random bottle on top so you can see how shiny it is...
Next up was to powder coat the 'non-raised' surface...
I choose wrinkle black because I wanted to match my valve covers and IAC cover. Here is what the lid looked like after removing the high-heat tape...
When I polished the plenum and runners I opted to clear powder coat them since it would be a real pain to remove them for polishing every so often, however the trade off is bit less shine. Since the lid is pretty easy to remove for periodic polishing I decided not to put clear powder over the polished part so I could keep it as mirror-like as possible.
I got some nice Stainless bolts that are the same style as the one on the IAC cover. I made a rookie mistake though and miscounted how many I needed and had to make a second trip because I was 2 bolts short
After getting the other 2 bolts I quickly polished the heads of all the bolts for some extra shine...
I used hylomar blue on each side of the gasket and the set the lid on and tightened it down.
I went to fire the car up and noticed that my 'smart' charger had died at some point which meant the battery was totally dead. So I put the car on the boost charger and tried to fire it up...
It fired right up ran for a couple seconds and died...
I repeated this a couple times and determined the fuel pressure is very low (15psi according to my fuel rail guage). However the fuel guage is reading empty so it might be out of gas or it might be some other issue with the fuel system, no leaks though.
I ran out of time for today but I'll let you all know what what i find.
-DMITTZ
-DMITTZ
