I'm finally dusting off my 84 and wanting to put it back in service. I bought some replacement outer door seals and discover they attach differently. When looking for other replacements I find the same problem. I did buy my c4 early in the year. Maybe things changed mid year? The replacement seals have a clip attachment. The originals appear to 'pop' in. I'm attaching a pic in case someone has solved this problem before. Thanks for any advice. - Don
I heard you just put the clips in the holes and push it in. Might need to open them up a touch. If there is a clip in the door might need to remove them.
