Quick driveshaft question....
Old Jan 3, 2017 | 08:51 AM
OldGyrene's Avatar
OldGyrene
Default Quick driveshaft question....
Pulled the driveshaft off the 1985 for u joint replacement. The dampener was loose, so I removed it. The piece that it was installed on looks to be pressed on, so I don't think I will mess with it.
The arrow on the shaft is pointing to what I assume are the balancing weights and look like they are attached with some kind of adhesive. As all three shafts are going to be balanced next week, can I remove these weights now ? What's the best method to remove them ? I want to finish cleaning up the shafts before I take them in for balancing.
Thanks.
Old Jan 3, 2017 | 09:29 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by OldGyrene
Pulled the driveshaft off the '81 for u joint replacement. The dampener was loose, so I removed it. The piece that it was installed on looks to be pressed on, so I don't think I will mess with it.
Thanks.
You mention '81 in your post - not that it makes a difference but I'd correct it if you could. Someone will hint that it's "misplaced" - I WON'T because it matters NOT!!
You're replacing the slip-yoke for sure I expect? If not which your post "hints" I might rethink that. I would leave the weights as they are and let the shop check with the weights as they are.
Old Jan 3, 2017 | 10:02 AM
OldGyrene's Avatar
OldGyrene
Sorry: 1985 (Fixed the post). You think I need to replace the slip yoke ? It is in great shape other than the dampener was loose. I researched a little and the consensus was just leave it off. Hmm...
Old Jan 3, 2017 | 10:11 AM
WVZR-1's Avatar
WVZR-1
Can't see the slip-yoke outer hub condition in the snapshot. If the shop says OK then it's fine. Did you pay attention to how it was indexed to the end-yoke on the shaft? Not as important since you've removed the damper and are doing the u-joints but we generally try to.
Old Jan 3, 2017 | 11:24 AM
OldGyrene's Avatar
OldGyrene
Yep. Marked everything. I will have them check out the yoke and order one if needed.
Thanks for the info & help
Old Jan 3, 2017 | 07:52 PM
OldGyrene's Avatar
OldGyrene
Default Sources for a yoke ?????
OK, so the shop guy says to replace the yoke, but I am coming up empty on a search. Anyone have any ideas or sources ????
Old Jan 4, 2017 | 08:41 AM
GUSTO14's Avatar
GUSTO14
Check with the folks at Inland Empire Driveline. If you order a drive shaft from Summit, these are the folks that build them. Great folks to work with.
Good luck... GUSTO
Old Jan 4, 2017 | 09:24 AM
OldGyrene's Avatar
OldGyrene
Good luck... GUSTO
Thanks, I'll check them out
Old Jan 4, 2017 | 09:35 AM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
You can also check Rock Auto
Old Jan 4, 2017 | 05:05 PM
WVZR-1's Avatar
WVZR-1
Your local drive-line shop should be able to supply this slip-yoke. It's correct length with NO DAMPER and DOES NOT HAVE the counter bore. Have them confirm dimensions for you. It's available in many places BUT if you ain't familiar with drive-line don't be guessing.
Spicer 2-3-4911X
Old Jan 5, 2017 | 09:00 AM
OldGyrene's Avatar
OldGyrene
Didn't find anything at Rock Auto, but thanks.
Old Jan 5, 2017 | 09:05 AM
OldGyrene's Avatar
OldGyrene
Spicer 2-3-4911X
Thanks for the part number ! I have all the measurements and will verify them against that number. We don't have a local drive line shop per se. We do have a place that will balance whatever you bring them.
Old Jan 5, 2017 | 09:12 AM
WVZR-1's Avatar
WVZR-1
If they balance, repair and fabricate then they shouldn't have an issue. I'd make sure if you're doing your own buy that you get SPICER by brand and NOT just a "knock-off" that many supply. The "knock-off" is likely fine but I try to avoid all of them.
Compare yours to this. I've bought many Dana/Spicer parts from here and it's Spicer unless he mentions it's not. I haven't checked the dimensions for a very long time. I'd assume the posted dimensions in this link are what I've experienced in the past. I've bought this one "locally" many times for others. I like to shop "local" - Local gets first opportunity almost always.
http://www.northerndrivetrain.com/pr...2-3-4911X.html
To Quick driveshaft question....
