replace Idle control valve
Old Sep 20, 2002 | 04:51 PM
How You Doing's Avatar
How You Doing
Default replace Idle control valve
Does anyone know how to replace the idle control valve on a 94 auto?
Is it very hard? Do I need a professional? If so, how much should it cost?
Thank you
Old Sep 21, 2002 | 01:01 PM
poppy's Avatar
poppy
Cruise-In III Veteran
Default Re: replace Idle control valve (How You Doing)
ttt
Old Sep 21, 2002 | 01:45 PM
JonM's Avatar
JonM
Try Tech Tips .... https://www.corvetteforum.com/techti...D=94&TopicID=2
Old Sep 21, 2002 | 09:45 PM
Lone Ranger's Avatar
Lone Ranger
I assume you mean the Idle Air Control Valve (IAC)? Super easy. About $65 part if I remember right, Jeff Kopp might be able to hook you up cheaper than $65 though. It is held in palce by two Torx bolts I think size 15 (or the next size up) It is mounted on the passenger side of the throttle body down low. Has an oval pigtail connector plugged into it-- a long oval. Not to be confused with the Throttle Position Sensor (TPS) which is mounted to the throttle body above the IAC and has a round pigtail plugged into it.
Once you have the new one installed, follow the C4 tech tip for IAC reset and you're good to go.
To replace Idle control valve
