I posted about a week ago that i'm going to do a coolant flush and
radiator removal for a cleaning. Got alot of nice replies. Thanks to all.
Now i'm going a little further with the project and need some more
suggestions. Where i live there are a few bridges and if they open to
let a ship pass you sit and wait. All the waiting and the temps go way
up.
I'd like to put in a 180* thermostat and a temperature switch that will
turn my fans on sooner. This C4 is a 1988. I've seen switches in
magazines, but don't have a clue as what to use. Thanks
Not sure what thermostat is in an 88 but surprised to find out that a 180 is in my1994. You may want to check out before you replace since you may be wasting your time.
My car runs at about 200 when "cool" . The downloaded owners manual says spec is 180. Wish they had put in a 180 because it's probably a 195 as you have pointed out
On a 195, probably sounds about right. I am not sure that you are going to see much more power dropping it to 180.
