passengers window
Old Jan 21, 2017 | 12:45 PM
rat123's Avatar
rat123
Default passengers window
Hi
I was wondering how I can get the passengers window tighter against weather-stripping. It leaks when I wash car. I own a 1984 corvette. Is there a adjustment. I'm will be going to take the door apart replacing some plastic trim so I was wondering if there was something I could do to tighten up window. The weather-stripping is all new.
thanks
Old Jan 23, 2017 | 10:16 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, there is a way to adjust the window.
Once the panel is off, you will be able to adjust the in/out position of the window glass from two adjustment "tabs" on the top of the door frame.
It will be pretty straight forward once you get the panel off.
Old Jan 24, 2017 | 04:42 AM
rat123's Avatar
rat123
thanks
I need to get the window tighter against the pillar. It leaks when I wash the car and there is wind noise when driving
To passengers window
