Any anti-leak additive available w/Dexcool??
I still have Dexcool in my C4 and was wondering if there is any additive available that won't harm anything. I don't have any leaks but would something be beneficial to add to the system just in case?
I personally wouldn't use an anti leak additive but I am sure there are plenty out there that are compatible with Dexcool. I don't think it would be of benefit and might actually make your cooling system less efficient.
2 suggestions. Fix the leak and flush everything out so you can use something besides Dexcool
In the 90's GM was adding these tablets to engine cooling systems and it can be used with DexCool.
https://www.amazon.com/Genuine-36346.../dp/B000QIH3C4
On page 6-168 of the 1996 Factory Service Manual, after draining and servicing the cooling system, 6 of those pellets are to be added into the surge tank.
The part no. has been superceded and is now P/N 12378255.
Last edited by Silver96ce; 01-25-2017 at 09:44 PM. Reason: OP doesn't know me (or anyone here for that matter) so who can he can trust; maybe GM
Atomic6 (01-26-2017)
Pro Mechanic
Stick to basic maintenance. If you feel you need to "Tinker", flush the cooling system and re-fill...and Dexcool is perfectly FINE for the fill. That will actually provide a benefit.
