Engine coolant temperature swing
Old Jan 28, 2017 | 07:30 PM
Erik Hansen's Avatar
Erik Hansen
Default Engine coolant temperature swing
Hi All,
I was driving my sons 1984 C4 today and noticed the coolant temperature got very high. It was around 250 when I noticed it. The temperature started going down pretty rapidly before I could pull over. Coolant temp got down to 170 so I kept driving. About 10 minutes later the temp started rising again and got back to the 250 range. Seems to continue doing this.
Any suggestions on what could be the problem?
Old Jan 28, 2017 | 07:51 PM
Edv92c4's Avatar
Edv92c4
Originally Posted by Erik Hansen
Hi All,
Could be thermostat sticking closed then opening when it gets really hot. I had a similar problem when driving my Caprice convertible home from Iowa (where I purchased it) back in 2001. Problem got worse so I pulled of the highway and bought a tool kit and thermostat and changed it in a parking lot in like Illinois somewhere. Car never overheated again...still has the same thermostat.
Old Jan 28, 2017 | 07:53 PM
Erik Hansen
That is for the reply. This is what my first then ught was as well. I'm new to corvettes and have heard that the 84 can be a tricky beast and the might have some thoughts from experience. Much appreciated.
Old Jan 30, 2017 | 03:15 PM
Erik Hansen
Default Solution to temperature swing and I'm an idiot
Thanks to seabright and Edv I found the problem. Coolant was nearly completely empty. I feel like an idiot now.
Now on to figure out where the coolant is leaking....
thanks for the feedback guys.
Old Jan 30, 2017 | 04:26 PM
don hall's Avatar
don hall
Now on to figure out where the coolant is leaking.....
It could be going to ground. As coolant heats it expands, and should flow to the over-flow bottle. If the gasket in the radiator cap is deformed, coolant will flow out of the neck to ground.
The cap may be original, so even if it looks undamaged, replace it with the proper pressure rating.
Check all hose ends for cracks and tightness. Look for wet areas on the fins of the radiator, and pressure test, if suspect.
If the rad is leaking, coolant would be more noticeable on the ground when you first park the vette when internal rad pressure is at its highest.
Depending where a leak may be located, evaporation of coolant may mask the source.
Check for dampness in passenger side floor for a leaking heater.
Check for any signs for a leaking water pump, and tightness for all coolant hose ends in engine bay.
Old Jan 30, 2017 | 05:07 PM
Erik Hansen
Thanks. I've topped it up with coolant and will keep an eye on it for areas you've pointed out.
Old Jan 30, 2017 | 06:53 PM
ToniJ1960's Avatar
ToniJ1960
If it came back down to 170 I bet it had to have had coolant. You night want to do a test for combustion gas in your radiator or sludge in the oil. Might have a leak in the head gasket. Mine would intermittently overheat replaced thermostat radiator kept thinking ok its fixed because it wouldn't do it for a couple days. But it kept returning. Blue Devil working so far 2 years now.
Old Jan 30, 2017 | 07:16 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
No worries, it is part of owning a C4.
I'm in the middle of a radiator swap project and I'll be an idiot at least twice later tonight
Old Jan 30, 2017 | 08:19 PM
scuba717's Avatar
scuba717
You can borrow a pressure tester from Advance Auto or other parts sellers and check for coolant leaks w/o hot coolant. Also a good way the bleed the system. Good suggestion to check the oil. Any white exhaust?
To Engine coolant temperature swing
