dead battery question
http://www.harborfreight.com/5-16-in...nch-97261.html
I have 2 questions.
1 is a motorcycle charger ok on a car battery
2 is this battery possibly still good or is it now toast? thanks,Nutsy
Another way to monitor your battery / charging system is to look at your digital voltage screen on the car-- if you have one for your year. Typically when first starting up the charging voltage will read something in the 14s. After 5-10 min. of running the car that number should start to drop slowly by tenths of a volt. For a battery in ok shape that number will get into the 13s, the lower the better, indicating that the battery doesn't need as much juice since it is accepting a charge. If after a half hour or so if you see that the alternator is still trying to push higher voltage into the battery, then that would be cause for concern about the condition of the battery. Now here is the bigger problem that we all should be concerned about and it isn't the battery. Batteries are cheap compared to alternators. I am guilty of this also. If your going to run around with a so so battery you are taxiing the alternator and shortening its life. You can buy 5-6 batteries for what an alternator costs and the alternator that you buy isn't as good as the one that came on the car to begin with. Reading the CF you will find people having major probs replacing their alternators. Walmart sells a battery for $48 bucks, $60 without a trade. It's made by Johnson Controls. Replace your battery every few years if you like and still be a head of the game.
AUGGY, you say it says don't leave hooked up, I wonder if its to prevent discharging or a fire?
I brought my battery to a shop that sells only batteries, mine was totally drained when I removed it, he said its reading 6.6 volts I guess. said he will charge it and then will know if its good. I figured since he only sells batteries he would definitely say it was shot. instead he showed me it was reading like 12.5 and said it should be ok. only charged me 5 bucs. good to know there are still some honest shops around here. anyway, I now have it hooked up to the tender AND PLUGGED IN. will check it in a couple weeks. thanks everyone again for all the very helpful info,Nutsy
http://bit.ly/2l6InNT
automotive fuse circuit tester has specially designed test leads that plug directly into your fuse box to quickly diagnose electrical problems. The tester can be used on all circuits up to 30 amps.
13.99
(Her fridge and freezer were a stinking mess too, but that's a different story!
If you haven't then I offer that the battery may not be bad at all and here is my experience as to why I say that.
Last year I left my battery hooked up in the car and only charged it occasionally with a battery tender style charger. I thought I had no issues as the light always turned green in a few minutes (probably less actually as I never physically watched it turn green but left it and came back in a few minutes to check on it). Then one day I tried to start the car to move it outside to clean the garage. Guess what. No start. I checked the battery with my VOM and there was 0 voltage.
Turns out the car's battery connections were not making contact inside the screw terminals of the battery. Call it corrosion or whatever you want. All I had to do was loosen the terminals and retighten them. Viola! Voltage. Of course I had to charge the battery again but the issue was not the battery in the first place.
Hope that helps.
Hope that helps.
