The passenger side floor light was burnt out and since I was going to be going into the driver's side to adjust the high beam switch, I figured I would install some LED bulbs while I had it apart.
Here is a before after of the driver's side.
Pictures were taken 1 day apart at the same time of day
Well
I changed out the Halos, door lights and the ones in the rear-view mirror.
Ran into a couple small problems with the rear-view. The factory bulbs come in from the back of the lens. The LEDs are too wide. So I ended up popping the lens out and putting the bulb in from the front. It worked but because the circuit reverses polarity to turn on the lights with the doors closed you have decide if you want to be able to turn them on with the doors closed or if you want them to work with the doors. Can't have it both ways.
