Led fog
Old Feb 22, 2017 | 08:32 PM
xrav22's Avatar
xrav22
Default Led fog
I bought these fogs for the low heat and long life(I run them on all the time)
http://www.ebay.com/itm/322186026968...%3AMEBIDX%3AIT
It states this
Power: High Power Chips (5 Watt per Chip,total 10 pieces)
I believe they are 50 watts, being LED I am to do the 15 fuse in the 10 and be good to go. Anyone confirm?
Thanks in advance.
Old Feb 22, 2017 | 09:46 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
50 watts @ 12 volt draws 4.16 amps.
Old Feb 22, 2017 | 10:12 PM
xrav22's Avatar
xrav22
Adding in the tails (no 3rd brake) does that make a 10 amp fuse ok.
Or do I need to do the 15 as others have done with fog upgrades?
Thx
Old Feb 22, 2017 | 11:18 PM
ben dover's Avatar
ben dover
Thx
1157s use about 9 watts so 2 of those would add about 1.4 amps. It won't
hurt to go to a 15 amp fuse to allow for line loss and corrosion at connectors.
To Led fog
