Its rather difficult to change the headlight bulbs in every vehicle I own and I am DONE with Sylvania bulbs. Have literally tried them all from the base bulb to their most expensive and they barley last a year if that. I'm looking for a standard replacement bulb (no LED, HID) nothing special, just some bulbs that might last a while!!
I know not to touch them and its not a electrical issue.
The C4 headlights flip and that probably does not help. The Toyota FJ eats one every six months on average and the GMC Sierra bulbs are a real pain to get to. DRL's don't help either. Turning them off does not seem to improve longevity.
Seems like Sylvania has the market cornered around here and its hard to find other brands. Any good heavy duty, long life bulbs out there?
When you're mentioning bulbs you need to be a bit more specific I believe. The incandescent from all vendors don't seem to be an issue and in most later production cases it's a connector or circuit situation. The C4 headlamp is a "sealed beam" unless you've changed and if OE all bulbs are incandescent except the FOGS!
Buy maybe Wagner but your situation is likely "where you shop" nearly all mass marketing do the Sylvania. Call some independent jobbers and ask for Wagner.
The C4 has Hella lamps with H4 bulbs in them. Much easier to change and the light pattern is perfect!
I had a single Wagner bulb that had been sitting around a while and put it in the FJ. Was quite surprised to see there was no difference in the output of it compared to Sylvania's so called "premium" bulb. I'll try a set.
Seems like the only bulbs that really lasted in the Sierra were the factory bulbs. They lasted 6 years. Anyone know what brand GM uses or who makes them?
In 120 volt A/C incandescent lighting they make 130v bulbs that seem to last forever for exit signs and hard to reach places. I'm wondering if anyone makes bulbs like that for vehicles.
I had upgraded the headlamps in my old '92 vert using the Hella european style lamp housings and H4 bulbs. They worked very well in terms of light output and the Hella Euro beam pattern compared to stock-style H6054 bulbs. I even used a higher wattage bulb and never had a problem with the wires, relays, or fuses.
Not sure if there is a headlamp that has a slightly higher voltage rating, but there are small bulbs (tail, brake, marker) that are rated for 14v. These bulbs will last longer than a bulb advertised at 12v but the voltage in many vehicles cvan and will fluctuate between 11v and 14v based on alternator output and battery voltage at any given time. In the 10 years I had my '92, I never replaced any tail/brake bulb or turn signal/parking bulb.
Would you post a picture of the hella lights(on and off, if possible)? Any modifications needed to install and use? Thank you in advance!!
The Sylvania sealed beams on my truck are eight years old. The PO put them on my 'vette at some point, and they're still working. But I've only had it 18 months (12K miles).
Mine no longer flip, so they get used a lot.
I've noticed that some vehicles just plain eat bulbs while others last forever. I am suspect of voltage regulator issues. My own cars' bulbs, mostly Chevy's and Honda's last many years while my daughter's BMW eats bulbs; all of them on an annual basis. It is not unusual to replace multiple tail light and front bulbs within a week or 2 of each other.
I have Hella's also. They are the 60/55 watt. I bought a set of 100/90
watt, but haven't tried them yet. Do you think i'll need to change the
plug to a ceramic on in case it heats up. My car already has a 15 amp fuse in for the headlights.
I've used Sylvania's in most of mine for quite some years without an incident. It's funny the comment about some vehicles chewing up bulbs, I've had that with one brake light without figuring out why. 10 years on one, and replaced the other 2 or 3 times within those same 10 years.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Since acquiring my 2000 Silverado two years ago, I've been noticing the vehicles on the road with one headlight/running light/parking light out. This is no exaggeration: 97 out of 100 vehicles with a light out are General Motors cars and trucks, usually Chevrolet and GMC, but Pontiacs, Oldsmobiles, and Buicks are in the mix to a lesser degree. Haven't seen any Cadillacs with this problem. Go figure.
Seems like the only bulbs that really lasted in the Sierra were the factory bulbs. They lasted 6 years. Anyone know what brand GM uses or who makes them?.
IDK but I bought some light bulbs to replace the ones in the car when a few blew out. They were the parts house Osram Sylvania variety. MB uses Osram too and their bulbs seem to last longer than the parts houses ones. But you do pay more.
One thing you see in the bulbs. The brighter it is, the lower the life it is rated for.
