c4 won't start
Old Feb 27, 2017 | 07:49 PM
skoto1's Avatar
skoto1
Default c4 won't start
got a barn find that has sat for quite a few years. installed a new fuel pump old one was stuck new fuel pump reg and it started right up. ran it for about 15 20 mins and turned it off. Restarted fine went in the shopped worked for about 30 mins went back out and no start no fuel pressure. this is the second time this has done this. thought it was the fuel pump but i guess i was wrong??
Old Feb 27, 2017 | 08:26 PM
aklim's Avatar
aklim
There is no rule to say it cannot be more than one thing. What does "no start" mean? Does it crank? Spray a little ether into the intake and see if it catches. If it does, stop spraying.
Old Feb 27, 2017 | 08:36 PM
skoto1's Avatar
skoto1
It will start with wd 40. not getting hot to pump for some reason. got dark i quit. replaced the fuel relay and a new pump again. like i said it started fine when i put a new pump in it and restarted a few seconds after i turned it off same thing happen with the other new pump. but after about 30 mins it cranked over fine just no fuel pressure. maybe a corroded fuse don't know where it's at but i'll find it and check it out in the morning. Car sat for several years.
Old Feb 27, 2017 | 08:45 PM
aklim's Avatar
aklim
Impossible to say. It should prime for 2 seconds after you turn the key to run. See if it is getting power. Remember, it primes and won't reprime itself for a bit more even if you remove the key so you have to wait a couple minutes for it to prime again. Check if you are getting power at the harness that meets the pump and go from there.
Old Feb 27, 2017 | 09:18 PM
xrav22's Avatar
xrav22
I have been keeping up on this subject in case I need a fuel pump. Anyways for my year 1985 the oil pressure needs to reach 5 psi for the pump to run.The oil pressure relay is behind the distributor. I don't know what year yours is but basic fuel pump change requires a new filter because if it is clogged it will ruin your new pump by not letting fuel pass like it should. Sounds like a find. Cllean all connectors when they come apart. Good luck
Old Feb 27, 2017 | 09:24 PM
2ljd's Avatar
2ljd
Where are you checking for pressure? At the Schrader valve?
Did you replace the fuel filter as well as the pump?
Old Feb 27, 2017 | 09:28 PM
skoto1's Avatar
skoto1
The car started and restarted several time. but after it sat for about 30 mins no fuel pressure. And no power to the pump , like i said may just be the fuse corroded will have to check it out tomorrow and go from there.. 1985 tune port. Thinking about jerking all this out and installing a big block I have carb and dis. no computer or other junk to worry about.
Old Feb 27, 2017 | 09:30 PM
skoto1's Avatar
skoto1
Yes. nothing barely trickles out.
Old Feb 27, 2017 | 09:33 PM
skoto1's Avatar
skoto1
Originally Posted by xrav22
I have been keeping up on this subject in case I need a fuel pump. Anyways for my year 1985 the oil pressure needs to reach 5 psi for the pump to run.The oil pressure relay is behind the distributor. I don't know what year yours is but basic fuel pump change requires a new filter because if it is clogged it will ruin your new pump by not letting fuel pass like it should. Sounds like a find. Clean all connectors when they come apart. Good luck
1985 did start several times and after 30 mins no fuel. just not getting power to pump now may just be a corroded fuse from sitting will check tomorrow.
Old Feb 27, 2017 | 09:35 PM
skoto1's Avatar
skoto1
recycled the key several times to prime and just left it on but no power to pump so it's not going to prime. check fuse tomorrow.
Old Feb 27, 2017 | 09:36 PM
aklim's Avatar
aklim
I thought it was to be a backup circuit to keep the pump going if the main line fails?
Fuel pump can run for over 30 minutes dry. Your motor cannot run that long without fuel.
Old Feb 27, 2017 | 09:41 PM
skoto1's Avatar
skoto1
Don't really understand what you're trying to say. No fuel am i getting and no power to the pump. Pumps not running now. Fuel filter new.
Old Feb 27, 2017 | 09:55 PM
xrav22's Avatar
xrav22
http://www.corvette-web-central.com/...etteStart.html
C4 start sequence , read this.
Old Feb 27, 2017 | 09:57 PM
aklim's Avatar
aklim
Fuel filter or the sock? Is the pump getting power at all? Did you replace the fuel pulsator with fuel resistant hose?
Old Feb 27, 2017 | 10:02 PM
aklim's Avatar
aklim
https://www.corvetteforum.com/forums...e-problem.html
Seems like there are multiple ways according to the diagram
Old Feb 28, 2017 | 11:56 AM
skoto1's Avatar
skoto1
Fuel pump relay plug was corroded a few sprays with carb cleaner and problem solved. It was unplugged the other day when it was running, i guess it is it's limp mode to get you home in case the relay goes out, and has been unplugged for years while sitting. Just didn't notice how bad it was. I thought plugging it in a few times would do the trick but i thought wrong had to really blast it several time but it did the trick. Onward and upwards i hope. Thanks for the input guys.
To c4 won't start
