Suggestions for clutch replacement
Old Feb 27, 2017 | 08:53 PM
Bwbob's Avatar
Bwbob
Default Suggestions for clutch replacement
All i want is a more or less stock replacement, 86 non modded but i would care for some input from people. I definately dont want junk but i am not headed to a drag race with this car. Sources and suggestions?
Old Feb 27, 2017 | 09:20 PM
hcbph's Avatar
hcbph
Check here and other corvette sites in the cars for sale section. Check Craigs List and other car sale sites for cars. Go look at a few before doing anything, get the feel for fit and finish. Decide if you want a coupe or convertible, manual or automatic tranny.
Go over it well. Check if someone is local that knows C4's and will go with you, members on many forums offer.
Check the fluids, check the seals (weather and mechanicals), age and condition of tires, age and condition of suspension. Insure that all the electrical items work. Check the condition of the interior and paint, look at the belts and hoses. Obviously look for previous body damage or repairs including repaints. Look at the condition of hte top or tops. Take a code reader if possible and see if there are any codes present. Now take it for a drive and preferably have someone follow you, watch how it tracks and for things like exhaust smoke. I'd go for something driven at least 2-3K a year, has not been in extended storage (meaning years at a time), has good maintenance records, the more the merrier. If it looks good, see if the seller is willing to let you have a mechanic of your choice look it over.
Personal thing here, I believe southern or western cars are less likely to have rust issues that northern or eastern ones. Just basing that on what I've seen, so take that with a grain of salt.
Know that an 86 has either 32mm or 38mm backspace rims (only 84-87 IIRC) and 16" diameter. Tires are still available but limited. Happens I just updated mine to 18x9.5" +40mm rims with 255x40zr18 tires. Fit perfect with no spacers required. Newer C4's have 17" with a 56mm backspacing and won't fit without adapters.
Got mine from a car auction in N.M. in 2013. I got the best I could for the money I had to work with.
Old Feb 27, 2017 | 09:43 PM
mtwoolford's Avatar
mtwoolford
check out the SPEC website, every clutch from mild to wild, flywheels also
Old Feb 28, 2017 | 05:37 AM
Bwbob's Avatar
Bwbob
All i need is a clutch, not a whole car. I dont think i could slip that past the wife
Old Feb 28, 2017 | 10:59 AM
856SPEED's Avatar
856SPEED
funny...saw the long post on advice on buying a C4 when you are looking for a clutch replacement.
I concur with the post above on SPEC. I run a SPEC in mine that is excellent. Carolina Clutch is who I deal with. I think Tom is the owner and knows a little about the C4 applications. Good luck!
Old Feb 28, 2017 | 02:57 PM
corvetteracer72's Avatar
corvetteracer72
Changed mine with SACHS K1911-01 kit . I had to resurface the flywheel. Works like a dream . Also it was affordable 160 USD.
Old Feb 28, 2017 | 04:04 PM
Klondike's Avatar
Klondike
I can tell you what NOT to bother with: RAM Clutches !
If you ever slip the thing just a LITTLE, (and I'm not talking about drag racing either)I mean easy like going up the driveway or into the garage, it stinks like burnt sea-shells for 1/2 an hour!
Also, apparently they have no clue what BALANCING means either.
Old Mar 1, 2017 | 08:58 PM
Bwbob's Avatar
Bwbob
Saks or Luk i think is my direction. I will probably not put 20k on the car from here and pretty sure my kid wont get to try burnouts either till he gets his own.
To Suggestions for clutch replacement
