C4 Hoods
Old Mar 4, 2017 | 11:31 PM
wheels777's Avatar
wheels777
Cruising
Default C4 Hoods
Are all C4 hoods the same. My 96 has a stock hood. I want to get another hood to install a scoop. Are they all interchangeable?
Old Mar 5, 2017 | 01:02 AM
bb62's Avatar
bb62
No, there are 4 different hoods depending on the year. 1984 hoods (the shell) is unique. 85-87 are common. 88-91 (part year) are common. 91 (part year) to 96 are common.
As for putting a scoop on the hood, not that you want my opinion, but most look awful. I'd keep the stock hood.
Old Mar 5, 2017 | 05:23 AM
corvettenorway's Avatar
corvettenorway
http://www.mirrockcorvette.com/corve...ooddifferences
Old Mar 5, 2017 | 06:07 AM
wheels777's Avatar
wheels777
Cruising
Thanks for the info.
Scoop/looks - I need the clearance.
Old Mar 5, 2017 | 06:26 AM
wheels777's Avatar
wheels777
Cruising
How do you tell them apart? Any identifying marks/numbers/features?
Old Mar 5, 2017 | 11:15 AM
Edv92c4's Avatar
Edv92c4
The above link to that site. Very informative. Learned things I didn't know. In the end, best hood to find is 92-96 as it fits all. (Except if you have an 84 that you are leaving stock)
Old Mar 5, 2017 | 11:49 AM
bb62's Avatar
bb62
1. What are you doing to the engine that requires a hood scoop?
2. If you buy a new hood with a rise in the center, it can look OK - in fact, some can look downright mean. But a grafted on hood scoop will always look like bubba made the modification.
Old Mar 5, 2017 | 07:49 PM
gman35's Avatar
gman35
one I did that is sitting in my backyard,
Old Mar 5, 2017 | 07:53 PM
gman35's Avatar
gman35
faux grill is bolted in.. removal sends air directly into engine bay. I was able to install it with factory bracing undisturbed.. used HD smc to mold it in.
Old Mar 5, 2017 | 09:16 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Originally Posted by corvettenorway
Thanks for the link. I learned some things from that site
Old Mar 5, 2017 | 10:34 PM
aklim's Avatar
aklim
For what? I cut a hole and put on a Greenwood hood scoop because I have a Holley Stealth Ram and it won't clear the hood.
To C4 Hoods
