ASR (yet again)
Old Sep 24, 2002 | 06:50 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default ASR (yet again)
To bring the topic of ASR up once again... I wanted to mention my thoughts on it on an auto equipped car vs a 6spd car now that I've been able to do a comparision.
In my 95 auto.. the ASR was VERY dangerous... it practically got me killed once and it really made me lose control a second time. When it kicked in it took control of the car and that's that.. it would stop you dead in the tracks at the wrong time.
In the 96 6spd car.. it's a totally different feeling.. if it kicks in, you notice it's there... but it's ever so slight. You don't feel as thou the ASR has control of the car.
Has anyone else had the chance to compare the ASR between an auto and a 6spd... if so... what are your thoughts?
[Modified by Springer's LT4, 5:58 PM 9/24/2002]
Old Sep 24, 2002 | 09:27 PM
85vetteguy's Avatar
85vetteguy
Default Re: ASR (Springer's LT4)
Never had auto w/ asr but my asr is not intrusive at all. I rarely even know it is on. Have heard the horror stories about the autos though. Guy
Old Sep 24, 2002 | 09:37 PM
Nathan Plemons's Avatar
Nathan Plemons
I've never driven an auto car with ASR but I have a feeling I wouldn't like it. I don't like auto's anyway. My brother has a 99 Z-28 auto. That thing will get you in trouble FAST. You pull out of a parking lot onto a damp road and it'll shift halfway through the turn. It shifts hard which breaks the tires loose and around you go. No thanks, I'll take control of the shifting myself.
Springer, on my 92 the ASR just plain SUCKS, and it's a 6-spd. It's the first year of the system and it's very sensitive and very intrusive. Are you coming to BG this year? If so we need to get in touch so you can drive mine and see what I mean. :cheers:
Old Sep 24, 2002 | 10:02 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well Jim, you know I have.
Omly problem is, my automatic has the Bosch 2U unit where my '95 and your '96(I believe) has the Bosch 5 unit. There is a huge difference between those two units.
But on my 6 speed, I can still break the tires loose ever so slightly without the ASR kicking in, and even if it does, it's only for a split second, you hardly realize it kicked in.
Now in the automatic, it takes a hell of a long time to recover from a little tire spin, so it is much more intrusive.
I can get the 6 speed car sideways with ASR on(did it tonight-on purpose) where the automatic car won't slide as well with ASR on.
So definitely the newer ASR which you had in the other car is clearly superior, I believe that the because of the six speed, we have one more factor to consider---your left foot. With the left foot obviously in charge of the clutch pedal, you have more control over what you and the car are doing.
You push the clutch pedal in and no power to the rear wheels, you let off in an automatic, there is still some power(although greatly reduced) going to the rear wheels(hey it sounds good in my head). So you gain more control by having the ability to manipulate the clutch to your satisfaction.
Old Sep 24, 2002 | 10:32 PM
GDP's Avatar
GDP
I haven't had any problems with my ASR. Today it kicked in for the second time since I've had the 'vette. I was on a road gravel everywhere and I went to turn right and as I was turning it kicked in. No problem, saved me from sliding, though I barely had my foot on the gas so I don't think it would have slid much at all.
Aside from that, it's a matter of availability and driveability with a six-speed. They didn't make a WHOLE lot; 6,012 out of 23,778 total in '94. Also, autos are better for track cars if you're into that thing.
To ASR (yet again)
