Ok now you might have messed up playing with it. Did you use the proper thermal grease?
Actually I have not removed it, but it looks like I will since I am noticing that white corrosion stuff around some of the edges and ICM looks a little rough like it has overheated..If their is corrosion between the ICM and the heat sink, that has to be a failure that is going to happen. The heat sink is dirty and greasy so I would like to clean it up also, so that it can do its job. I noticed this when I was looking at the coil to see how hard it would be to replace. I intend to carry a spare coil with me in addition to a spare ICM. I shop at Advance or Autozone. Could you tell me exactly what it is called and who makes it? Be specific if you can. I hear you put it on very thin, is this true? Many thanks
Are you referring to Dialectic Grease? Number of companies make and sell it. Thin is better in most cases.
NO! The paste is NOT dielectric grease, don't try to use that as it will have the opposite effect as intended. The thermal paste is intended to transmit heat from the ICM to the heating. And so has a high metallic content.
Autozone sells it, part number SL203.
That's why I asked. Sounds like something similar to heat sink past used in computers etc based on your description. Then again, I'm assuming you're referring to something 'not' used on electrical connections.
It's very similar to the thermal.paste for computers. Supposedly that stuff can drip for a lack of better terms, but I bet the thermal paste in cars is virtually the same as that stuff.
Your dead on about the not dielectric grease. This stuff is hard to find. Autozone 10 miles from me, will check it out after snow storm here. This product is supposed to be a white paste which I confirmed after removing ICM from my Corvette. Heavy duty thanks.
When I replaced mine, the guy at AZ had to dig thru a box in the shelves to find the paste. It comes in a small pack like ketchup. I also got longer screws and some delrin washers (couldn't find any phenolic washers) to space the ICM and heat sink away from the head. Not sure how well that works to lower heat to ICM.
I was thinking of picking up a pertronix HEI III module as I'm going to do a major tune up this spring. New Rotor, Cap, High Energy Coil, Ignition Module, Wires, and plugs.
Anyone have any experience with the Pertronix Module?
The heat sink is designed to heat sink to the head :-)
That's why you use the grease to take up the small surface imperfections between the two components. Improves the thermal transfer from the ICM to the head. High heat applications sometimes use a conductive rubber compound. It's mixed with silver or copper. Not sure it would work here or be needed or cost effective. Seems like the grease does the job.
I found the thermal paste at Autozone. Comes in a very small packet with a very small amount. ---- Just one other thing. If I plug a new coil in, by the side of the road, does it have to be attached (grounded) to the car. I am assuming it does not, just like the ICM. Removing the coil bracket is not a by the side of the road job. The engineer who designed this should be.. ...... Thanks
Good that you found the thermal heat sink compound, but it needs to transfer that heat away from that metal bottom to keep the ICM from overheating. Electronics parts stores sell all kinds of little finned heat sinks for transistor power projects. Get one that has a flat surface about the same size as the ICM and drill a couple of holes in it to mount it to the ICM. Apply the paste between the two and you'll have a stand-alone unit. Even a piece of flat aluminum with a little larger surface area will work just fine. You just need a little extra air cooling surface area to help those power transistors transfer the heat out of the unit. Also when you replace the one on the car, put fresh thermal grease between the heat sink and the front head surface. That stuff dries up after a few years on the car.
90's 5.0 Mustangs have a similar problem with the module that mounts on the distributor. Built a spare plug-in that I carried with me that saved me and also rescued a couple of friends.
