courtesy Lamp Delay Module
Old Mar 11, 2017 | 06:22 AM
ubunturon's Avatar
ubunturon
2nd Gear
Default courtesy Lamp Delay Module
I've been trying to locate the courtesy lamp delay module and have not found it. Is there a procedure to locate and replace/repair the module? It is for a 1984 Corvette.
Ron
Old Mar 11, 2017 | 01:54 PM
hcbph's Avatar
hcbph
If it's like my 86, it's taped to some of the wiring harness under the dash on the passenger side. I spent a fair amount of time trying to find it once but came up empty. At some point I'm going to be replacing the breadbox with a flat panel and figured I'd track it down then.
Good luck.
Old Mar 13, 2017 | 01:59 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Yes, it's the same in the '84. It's on the same wire bundle as the turn signal flasher. The flasher is easy to find if you activate a turn signal!
ubunturon, check your Private Message file, in the Welcome box in the upper right corner of this page.
Old Mar 13, 2017 | 07:31 AM
Gibbles's Avatar
Gibbles
Mine was taped to the harness with what looked like masking tape.
Also a super common issue, i fixed mine for about a dollar.
just need a soldering iron and some love.
To courtesy Lamp Delay Module
