C4 engine miss firing
If you have a miss, I'd put some fresh gas and some injection cleaner (high concentration) and run the snot out of the car for a while.
If dead, you need to do a full on injector service.
The other thread that I've been following, the guy says that 5 6 &7 are down on his car too ....????
What we want to do is rule something out as opposed to guessing something out.
Wait until it is dark, open the hood and start the car. If a plug wire is broken or chewed then you will see sparks jumping from the wire(s) to the nearest ground. Replace the plug wires if you see any of this.I you do go with new injectors then use Jon at Fuel Injector Connection. Great service and prices.
Be sure to replace those old O rings in the fuel rail too.
I don't know about others but I don't reuse my condoms or my buddies' condoms. Same with O-rings or paper gaskets
here is how i would do it to avoid spending un-needed money swapping parts and avoid spending unneccesary time pulling injectors.
1. ohm test. (if they are not all more or less the same, this is an immediate knock out blow and you need to get new ones) note, as Ak reminds us, good ohm does not meat they cannot be plugged or partially plugged so passing the ohm test on its own will not veryify if they are good.
if pass then
2. listen to the injector click click click click with a stethescope or long flat blade screwdriver, put the handle end right into your ear. the ticking nose should be the same across the board. Here is an example of having one quiet injector: https://www.corvetteforum.com/forums...-injector.html
if all your injectors are ticking along, it still does not rule out a clogged injector.
3. next you have to verify spark. pull your spark plug on the "dead" cylinders and on the closest "good" cylinder. unplug the fuel pump fuses and the injector fuses. now get somebody to crank the car and hold the sparkplugs boots in your hand and compare the two different spark qualities. Again, as Ak always reminds us, make sure the spark is loud, snappy, and whitish bluish. If not, then you have a problem in your dizz, or plugs themselves, or plug wires.you might want to set the spark plugs on a tire or a piece of rubber. You might get zapped if you are holding the boot.
I realize you said you did the cap and rotor but that doesn't mean anything if your pickup or ignition modlue or coil or grounds in the cap are gone.
If everything looks good so far, then you most likely either have no compression in 3 cylinders (highly unlikely right??) or you have clogged/seized injectors.
But because I don't like tearing down the TPI intake if I don't have to, grab your compression testor and test compression. if you get one or two values lower than others, then you need to squirt oil into those spark plug holes and then try again. if the second cmpression run after you have squirted oil into the spark plug hole goes higher, then you have worn rings and you will likely want to stop and evaluate the future of the car. If the compression is unchanged then you will have a valve seat job to do.
If compression is good all the way around (within 15lbs of each other) then we have one thing left in this case:
4. clogged injectors. you will need to tear down the TPI intake, if it is your first time, then bag and tag using clear sandwhich bags and write on a sharpie details of the bags contents. pull the injectors out and if they are multecs, replace with new from Jon and FIC. IF they are not multecs, you can clean them yourself, this worked for me but I know that others will say for the $$$ just get new ones. At my location they cost $600 landed to me so I chose to attempt to clean mine myself and it worked fine. That said, I did not have a major occlusion problem. My method may not work if they are really really clogged, and my method will definately not work if they are occluded with solid particulate. That said, you can observe the spray pattern using my method and you will know if they are brutally clogged or not. In my case the spray pattern was "matched". I am not saying be cheap, but just if you are in a pinch for $$ you CAN do it yourself.
Or just buy new ones and go for it. If you have a plugged injector that is so bad it can't fire, you WILL see a major difference in those spray patterns using this method.
5. If you find that your spray pattern is the same.....or...if you replace the injectors and find that our still have the miss....then i don't know. I think we would have to look at wiped cams, that sort of thing.
I wasted a heap of $$ replacing parts that turned out to be good. I've become a master of diagnosis now. Saves me a heap of time and $$. Good luck with it.
Good advice but I'd go one better and use masking tape on the bags to mark the contents. On my builds seems if I handle the parts bags more than once the Sharpie notations go "poof".
later, tiny
if pass then
https://youtu.be/tskGLn0qp0I
I have new injectors coming, but the old ones ohm good, 16.8. I haven't checked the spray pattern, but am going to replace them anyway.
The problem now is how to get the water out without pulling the tank off. ??? Do you think that if I pull the filter, and run the fuel pump, that it will get enough out that dry gas will take care of the rest ? The water will be at the bottom, and I don't expect that there is much in it now. I let it drain, and didn't seem to be getting anymore water after a couple gallons.
Another thing, is the cold start suppose to ohm the same as the injectors ? Mine is 4.5... Thanks for all the help, you guys are great
Don't care what it ohms out at since you are replacing it.
WGAS. Dump the fuel. Take the pump out since it is stupid easy. Suck out the gas out, let it sit in the tank for a bit and pour most of it out and set fire to the rest. The old gas you can use in your neighbor's lawnmower, set your neighbor's yard on fire or whatever. That is about all it is good for. With the gas out, you can use a dry rag and soak up anything left. Let it dry for a day and check again. If it is dry, dump 2 gallons of fresh gas in in and let it sit. Suck it up again and this time you can reuse the washing gas in your lawnmower safely.
Who cares? Let Jon take care of it. He can service that one and send you new O-rings. Now you have a complete set. Another option is for longer crank times and you block it off or you can also block it off and have someone increase the pulse width during crank. 3 options.
