Snapped bolts on 1986 corvette throttle body
Was cleaning my throttle body and the bolts that hold the lower piece to the throttle body broke off. Was wondering what size they are and were can I get new ones? These are the bolts that are applied with a torx bit screwdriver. It is off of a 1986 corvette
The heads on every single one of mine snapped off. I can't remember the size other than they are metric. I bought a hex head set at Home Depot to replace them with.
the screws are M4-.7 torx, pan or round/button head. not sure of the length, but most likely between 20 and 25mm - standard, off the shelf, sizes are 20, 22, and 25mm, and if I had to guess, i'd say 20mm. as I recall, they are all the same length, and also, I vaguely recall having lock washers. again, ??? it's been years ago, but I bought replacements at my local hardware store - same, but pan head/allen recess. i also recall, a torque value of 27 INCH pounds (double check for your application). this is a case where stainless steel would be a good option.
edit: guessed wrong - not 20mm, but maybe 25mm...
just ran across a small zip-lock bag with three, M4-.75 x 25mm round head, allen recess that i'm thinking I bought years ago when working on my 85's TB. there were also a couple of 4mm lock washers in the bag. so, FWIW, i'm guessing the OE length is maybe 25mm.
here's a link for SS replacements...
https://www.mcmaster.com/#92095a197/=16wrppp
If your refering to the four bolts that secure the throttle body to the plenum, I have four i removed from my 85 L98 and replaced them with Stainless Allen heads. They are hex head, black flanged b olts. You can have the old ones as I have no use for them. If you want them PM me with a address and Ill send them out Monday. Im assuming 85 and 86 are the same
