thank all
for the moment my corvette not move ( i have deconnected the fuse for dash to start relax the car and no broken )i have testing the volt betwin negative battery and motor , i have 11 volt . the alternator product betwin 14,5 to 15 v . i don t no from where the 11 v are in the motor body ( and i think it s this problem push the dash v at more than 16v ) , i have cleaning ground ( i hope not lose one ) .
if you have idea where from this 11 v ?
good week end for you , i come back to my corvette to check + connector os if one red wire touch metal ....... .
You have found your problem! You have either a bad cable between the neg. terminal of your battery and the engine, or bad connections of that cable.
i make mistake , is not 11 v but 11 mv ( normal v ) now i am near sure problem is in the dash cluster ( i think is capacitor , the sound inside is like full capacitor v ) i send cluster to bates to check test . i inform you the information from repar company . than again for your help and your are welcome in france
best regards alain
